Old March 27, 2010, 06:27 PM
Originally Posted by Photograph View Post
Can I run the SMP2 client alongside two GPU clients? I have tried to run the GPU and the SMP at the same time and i got an error stating only one client can function at a time.
You can. I suspect the reason you got that message is because you didn't change the clients' machine IDs. Each client has to have a different machine ID to run.
haha ok...btw, for the bottom card, do you have enough space below the mobo? may want to direct direct flow on the bottom card
Old March 28, 2010, 12:28 AM
CroSsFiRe2009's Avatar
Don't think 1x pcie slots bottleneck f@h much even.
As for cooling, I say ditch that fancy cooling and just strap remove the shroud from the heatsink and strap a 120mm fan over on top of both video cards
Soup and sandwhiches or building a less then $2000 gameing machine Victom New Builds 1 November 19, 2009 09:36 PM
Dual GPU Folding on one GPU (FahCore_14 only) geokilla HardwareCanucks F@H Team 2 August 8, 2009 05:35 PM
Need help looking for a board that will run Crossfire at dual 16x mode Gameplaywarrior CPU's and Motherboards 4 July 9, 2009 01:44 PM
Dual CPU slot board? 3.0charlie CPU's and Motherboards 19 February 1, 2008 07:30 AM
Building a dedicated Folding machine Gav HardwareCanucks F@H Team 38 August 27, 2007 10:35 AM
