Old March 15, 2010, 10:21 PM
Default bigadv folding help...?!
I downloaded and tried to run Linux64_FAH the newest version, but when I try to start it, VMware Player (newest version) says something about not being able to run 8 CPUS, only 4 ... will only start if I put it to 4. When I start folding using ********* -smp 8 my CPU load is only at 50%. VT is enable in BIOS.
What am I doing wrong?
Thanks guys!
Old March 15, 2010, 10:30 PM
lowfat's Avatar
You need to run the VM Player 3.0.0. Anything newer only supports 4 threads.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old March 15, 2010, 10:52 PM
perfect it works, thx a bunch lowfat.
while i'm at it, i've googled for guides to set it up with fahmon, found some, even the one from our own chriskwarren, but it seems it doesn't want to work. any1 can point me to a known working guide or simply explain?
Thanks again!!!
Old March 16, 2010, 04:30 AM
I think you are better off with HFM.net for monitoring client, because fahmon doesn't calculate bonus points.
Old March 16, 2010, 05:25 AM
Alpine's Avatar
true, Fhamon is not able to caculate the bonus ! HFM.net is very easy to setup, same way of fahmon.
Old March 16, 2010, 10:46 AM
When adding a new client .... log folder, where is it located?
Old March 16, 2010, 11:11 AM
lowfat's Avatar
for linuxrouters image it would be \\FAH\fah\ if you used the default location.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 16, 2010, 11:20 AM
That's the problem, can't seem to find it. there is no fah folder in my main FAH and I didn't change anything. I can easily find it all for when I was using notfred, but can't find it for this one ....
Btw thx for the help again lowfat, folding away on 8 cores!
Old March 16, 2010, 11:33 AM
lowfat's Avatar
There is a good chance if you can't see it on your network it isn't getting an internet connection. And when the time comes to upload once it is complete it will fail. I just lose another (likely my 10th bidadv ) because of this. Try rebooting the client and see if that helps.
Queen of Dreams WIP
Big Lian Li
Complete
Old March 16, 2010, 11:59 AM
SugarJ's Avatar
Isn't it \\ipaddress\fah ? i.e. \\192.168.0.197\fah? The VM shows the IP address it is using when it boots.
Issues w/ bigadv lowfat HardwareCanucks F@H Team 8 March 8, 2010 03:44 PM
IMPORTANT FOR BIGADV USERS: -bigadv workunits now require the 6.29 Linux SMP client Zero82z HardwareCanucks F@H Team 9 February 9, 2010 04:35 PM
Bigadv a1 phil3_66666 HardwareCanucks F@H Team 8 February 6, 2010 09:06 PM
Lost my bigadv MarkOne HardwareCanucks F@H Team 19 January 26, 2010 07:05 PM
notfred's Folding Virtual Appliance -bigadv variant: now with v6.29 SMP client Zero82z HardwareCanucks F@H Team 15 January 24, 2010 11:14 AM
