Originally Posted by Arinoth -advmethods -forcegpu nvidia_g80 -gpu 0
-advmethods -forcegpu nvidia_g80 -gpu 1
Also having 2 folders, one for each core in user\roaming This allows you to fold with or without SLI enabled and without a dummy plug |
First part is correct, but you do need SLI disabled.
Originally Posted by geokilla Um, SLI enabled or disabled doesn't matter if I remember correctly with the later drivers.... |
SLI needs to be disabled w/ 9800GX2s (and possibly GTX295's). All other cards SLI can remain enabled.
