Old October 16, 2007, 10:51 AM
qwerty's Avatar
Default Some questions about F@H
In a couple of weeks my new rig will be ready at which time I would like to run this machine full time to F@H...now for the questions.
1. I would like to unplug the monitor and just leave it in a corner someplace folding away forever. Is this possible?
2. The machine in question is a P3 733 512 megs ram, etc, pretty old. But can it still fold?
I would install and configure Linux on it if it would help to speed it up some.
Hrm that's about it. If anyone could help me with this I'd appreciate it. Thank you.
Old October 16, 2007, 11:07 AM
Yes and Yes.
If you run Windows you can setup a RDP to access it after you remove the monitor. If you run linux you can setup SSH to access the box as well.
While you may want to use a higher speed processor, any system can fold it may just take a bit longer.
Old October 16, 2007, 12:37 PM
qwerty's Avatar
Originally Posted by enaberif View Post
Yes and Yes.
Ok good.
That's fine. I don't plan on checking my progress all that much. I just want to do my bit for a good cause. It'll just be sitting there folding....doing nothing else at all.
Thanks for the speedy reply.
Old October 16, 2007, 12:42 PM
Ok good.
You can also get a program called Fahmon which can show you the progress too.
Old October 16, 2007, 06:45 PM
Fallen Folder
That box will not produce very much but every bit helps. As we move into the colder season the power cost will be offset some by its heating.
For monitoring, as enaberif said, fahmon should be sufficient. You just need a share set up to its folding directory from you main rig, and run fahmon on your main rig. If it isn't folding then just plug a monitor in to see whats wrong. VNC is another free remote desktop tool. Remote desktop software won't help if the machine hangs.
I don't think linux would help production (might even be worse depending on the work units the rigs is assigned) but is a good choice if it saves the cost of a windows license.
Keep an eye on it with fahmon to make sure it will meet the deadlines ... it should but if it doesn't then there is no point in folding on it ... it will be wasting energy and slow down the science.
Questions and Recomendations Brando737 HTPC Systems & Software 2 September 20, 2008 09:25 AM
Please Help~answer the questions> < dracozhu Troubleshooting 6 March 8, 2008 02:17 PM
Partition Questions mattydies Storage 6 December 23, 2007 04:57 PM
Cooling questions... Jaret Water Cooling 35 December 11, 2007 05:48 PM
some questions about the pc... omgwtf CPU's and Motherboards 17 August 17, 2007 09:44 PM
