Old February 19, 2010, 08:52 PM
martin_metal_88's Avatar
Originally Posted by MarkOne View Post
why you look in the mirror
no there was a mistake in the start file fixed and working:)
now gettin 3500PPD frmo your 250 mark hope to get more soon with a little OC:)
Old February 19, 2010, 08:53 PM
MarkOne's Avatar
without OC I was getting 5-6k ppd with a 250 you jsut get a bad WU
Old February 19, 2010, 08:56 PM
theres no such thing as a bad wu..crapper ppd wise? yup :D
with the new wus itll be pushing 7 or more k maybe :)
Old February 19, 2010, 09:03 PM
well actually CPU and 250 have low PPD so I hope to see some better unit tomorrow:P
Old February 20, 2010, 08:33 AM
shaw
Guest
Posts: n/a
If you are both CPU and GPU folding, don't forget to adjust the GPU Core Priority to Above Normal, using Prifinitty (or other similar apps). This will give you a nive boost in ppd.
Old February 20, 2010, 09:16 AM
I have done it for the 260 but I will have to take a look if I do it for the 250 client
Old February 20, 2010, 09:52 AM
you have to set it to above, on one core right?
Old February 20, 2010, 10:52 AM
I will also take a look to fold CPU -bigadv on 7 core and let the last one for GPU maybe I can get more PDD like that I will have few test to do before to confirm to you.
Multi-GPU Folding doup93 HardwareCanucks F@H Team 8 December 16, 2009 12:07 PM
Multi GPU Setup help SugarJ HardwareCanucks F@H Team 12 November 18, 2009 05:57 PM
Multi-GPU Problem *sigh* Soultribunal HardwareCanucks F@H Team 23 October 30, 2009 10:26 PM
Multi GPU folding - need help Apollo4g HardwareCanucks F@H Team 4 July 17, 2009 11:13 AM
Multi-GPU PhysX implementation BrainEater Video Cards 16 May 7, 2009 03:54 PM
