-   HardwareCanucks F@H Team (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/)
-   -   9800 GX2 an Win 7 aaaaahhhhh (http://www.hardwarecanucks.com/forum/hardwarecanucks-f-h-team/28874-9800-gx2-win-7-aaaaahhhhh.html)
matsta31 February 13, 2010 05:03 PM
Cant seem to be able to start my second 9800 Gx2 gpu on win 7.... What I am trying to do is to get the dekstop to the second gpu, but it seem window 7 does not want to do it, because it can see another monitor.
I know the flags -gpu 0 and -gpu 1 becasue my shortcuts were working on XP. So, after looking around, I suppose I need a dummy plug ? or did I miss something ?
phil3_66666 February 13, 2010 05:06 PM
i can fold on bolt core of my gtx295 in win7 ultimate 64(without dummy plug), even on a 9800gt in the same rig without the dummy plug, i just can't say how i do it since i try thing over thing for hours and got it working by chance...
_dangtx_ February 13, 2010 05:06 PM
refresh it, then when it detects 'empty monitors, reextend that. makesure you got a monitor(or the same on another cable) connected. with xp id set it up once and forget it. win 7? had to do it from time to time. a major pain..win 7 and folding arent very good frends.
lowfat February 13, 2010 05:10 PM
You need a dummy plug or a monitor plugged in to each 'card'.
matsta31 February 13, 2010 05:38 PM
yeah ok thanks, that I what I tought. So how tough is it to do a dummy plug ?
where could I find a dvi cable (I got to plug on my LCD) for cheap ?
lowfat February 13, 2010 06:31 PM
Really easy.
The 30 Second Dummy Plug - Overclock.net - Overclocking.net
I build 4 of them in like 2 minutes. And I made mine all pretty w/ heatshrink.
matsta31 February 13, 2010 06:40 PM
lol yeah easy :) Thanks for the link !
10e February 16, 2010 09:59 AM
You might be able to get away without using the dummy plug if you just add -forcegpu nvidia_g80 to the second GPU client's options.
Apparently this works with the newer 195.xx ForceWare drivers (methinks). Try it and see if it happens.
lowfat February 16, 2010 10:11 AM
Not w/ the 9800GX2's. They are in a league of their own. :blarg:
_dangtx_ February 16, 2010 10:55 AM
if you manage to get folding going left and right on windows 7 gpu and such, either you got lucky or spent a good couple afternoons working on the problem :)
