<~----> -bigadv on a I5-750 ??? - Page 3 - Hardware Canucks
  #21 (permalink)
Old February 1, 2010, 12:27 PM
martin_metal_88's Avatar
Cmon mark don't tell me you forget to enable the -Advmethod when advanced setting ask for it:P And there is no more need for folding you already pass me in ranking XD
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
  #22 (permalink)
Old February 1, 2010, 12:36 PM
MarkOne's Avatar
Thanks Zero but I don't touch anything for now ..... look at the JP-CPU1 CPU2 and GPU ...my son and wife use it time to time , if it create a problem I will just shut down the CPU2 in the day , it will be better than the 400 ppd I have before , if this 55k PPD + the coming 2 * 920 is not enough... for keep me in the top 20 .. I drop it
  #23 (permalink)
Old February 1, 2010, 12:38 PM
MarkOne's Avatar
Martin it's a 4 core no Hypertreading.... if I don't bought my 2 920 I will change the 750 for a 860.. but if you add the 4 gb more than I need for it + $ 130 for the 860 it's not worth
by the way the Gigolobite EP55 start to p...me off for real.. the temp of the NB don't work. the keyboard stock in the bios ( same g11 as you )
  #24 (permalink)
Old February 1, 2010, 12:41 PM
SMP2 is easier to shut down and start up than running VMs, it uses less resources, and it puts out a lot more PPD. It's worth the small amount of trouble to set it up just to save you some time and effort in the future.
  #25 (permalink)
Old February 1, 2010, 12:44 PM
MarkOne's Avatar
ya but it does not work for now with this 8676 port problem.. will try later when I have a 920 running to not lost too much PPD
  #26 (permalink)
Old February 1, 2010, 04:44 PM
MarkOne's Avatar
On don't say my final word on that..... the linux client or the ntfred one don't want to install because they don't see 8 cores.... My bigadv on my 860 will finish soon. I will restart an other setup on it put the smp -4 , and after transfer the folder to the 750 rigs , may be I gone have an error, may be it gone work ...we will see
  #27 (permalink)
Old February 4, 2010, 05:35 AM
MarkOne's Avatar
It's one hour I read the instruction for the SMP3. ...... I find the problem... get ready to see some improvement...
  #28 (permalink)
Old February 4, 2010, 03:35 PM
MarkOne's Avatar
Originally Posted by lowfat View Post
It isn't going to be possible w/ the 750.
you beat I gone try it .. I don't believe that 4 fake core ( the HT ) make a big difference. We will see. and if It close at 4,2 ... I will take the next phase ...as in phase cooling.. and see what surprise this ROG board have to offer.
Lost my bigadv MarkOne HardwareCanucks F@H Team 19 January 26, 2010 06:05 PM
notfred's Folding Virtual Appliance -bigadv variant: now with v6.29 SMP client Zero82z HardwareCanucks F@H Team 15 January 24, 2010 10:14 AM
Important; SMP Client Updates; Including -bigadv LCB001 HardwareCanucks F@H Team 13 January 22, 2010 06:07 PM
-bigadv bonus in FAHMON martin_metal_88 HardwareCanucks F@H Team 9 January 16, 2010 08:01 AM
Setting -bigadv martin_metal_88 HardwareCanucks F@H Team 37 January 11, 2010 08:10 PM
