Old January 29, 2010, 05:47 PM
Spikemaul's Avatar
Default Problems with SMP Client
Hey guys, I decided to give the SMP client a go and after stopping it to do a restare I get this:
Name:  1-29-2010 7-43-55 PM.png
What's this mean and how do I fix it? The GPu client I have going doesn't gie me any problems like this.
Old January 29, 2010, 05:51 PM
3.0charlie's Avatar
Did you run the install.bat file?
Old January 29, 2010, 05:52 PM
Click the install.bat first before u load the client. This enables the MPI.
unless the one file/service was affected, from what i get is that it did run,he stopped it, then that.
either way, the above post points the way :)
Old January 29, 2010, 08:06 PM
Are you using a shortcut by any chance? Make sure the "Start In" property of the shortcut is pointing to the folder that has mpiexec inside it (e.g. your main folding folder).
To see if a bugged shortcut is your issue, I recommend trying install.bat and then running the folding using the command line. If the command line fails, then your problem lies elsewhere...
Old January 29, 2010, 08:20 PM
Spikemaul's Avatar
Thanks for the help guys, I didn't install or configure the .bat file first. I first skimmed through the FAQ guide on Stanford's website but the second time I actually read through it and it all came together. I got it going and my room's now warmer.
Old January 29, 2010, 08:30 PM
geokilla's Avatar
Are you using SMP2? If you are, I hope you're a dedicated folder and fold 24/7. Otherwise I'd suggest you run A1 and A2 WU. A2 WU can be run using Linux or VMware image folding.
A3 WU Bonus Points Woes For Non-dedicated Folder
Old January 29, 2010, 08:43 PM
Spikemaul's Avatar
The GPU's going 24/7 so I figured why not the CPU
Can't setup SMP client Lamb HardwareCanucks F@H Team 17 December 10, 2009 03:04 PM
SMP client help phil3_66666 HardwareCanucks F@H Team 17 April 24, 2009 09:34 PM
Need help setting up SMP client Alwaysrun HardwareCanucks F@H Team 7 February 8, 2009 06:47 PM
Goodbye SMP client ! BrainEater HardwareCanucks F@H Team 3 November 2, 2008 04:17 PM
SMP client errored BrainEater HardwareCanucks F@H Team 8 October 9, 2008 05:50 PM
