Old January 20, 2010, 08:33 PM
Default Videocard lifespan
Was just wondering how long a videocard will last before it bites the dust when you are folding with it 24/7.
All my cards are running stock clocks right now with temps below 70 degrees. I also have 120 mm fans blowing over all the cards. Does overclocking the shaders reduce the lifespan?
Old January 20, 2010, 08:47 PM
Dead Things's Avatar
You'd be surprised. My video card death count due to folding is at precisely zero, and I've got about 30-40 deployed at any given time.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old January 20, 2010, 08:49 PM
Arinoth's Avatar
It really just depends on what temperatures you run them at. The higher the temperature you run them at the slightly lower the lifespan of the graphics card is. If you run it within a reasonable/safe temperature at full load you wont be damaging anything as it was intended to work at that, but when you get into the much higher temperatures thats when you may potentially be shortening the lifespan of your GPU.
Here I am: here I remain
Old January 20, 2010, 08:54 PM
LCB001's Avatar
Folding Captain
The Asus 9800GTX in my Rig1 has been Folding 24/7 with highly clocked shader for over 18 months and finished over 6200 WU's and is still going strong.
YMMV, good luck...
Folding For Team 54196
Old January 20, 2010, 09:11 PM
chrisk's Avatar
Folding Captain
Better to die quick fighting, than idle long in your case!
Fold for team #54196
Old January 20, 2010, 09:22 PM
Good point... they will be obsolete in a year/year and a half anyway. May as well put them to good use.
I was under the impression that running the cards full tilt would significantly shorten their lifespan. Had visions of me having to remortgage my home in 6 months to replace all the toasted hardware...
Old January 20, 2010, 09:26 PM
You'll still have to remortgage your house to pay for your new fah addiction. But the hardware should be fine.
Old January 20, 2010, 09:38 PM
Assuming the card isn't defective in some way that would cause it to fail prematurely, there should be no effective decrease in the lifespan of a video card from folding with it 24/7. Also keep in mind that F@H puts less stress on a video card than gaming does.
Old January 20, 2010, 09:46 PM
MarkOne's Avatar
you know someone who play 24/7
( p.s.) no need for big theory it's a joke
Old January 20, 2010, 10:00 PM
as long as you get a solid product, and as said 2 times you kep temps i ncheck, i would give it a safe 2-3 years or longer 24/7.
New Videocard lcdguy Video Cards 13 June 27, 2009 05:15 PM
[WTB] Videocard 8800 GS/GT Inik Buy/Sell & Trade 2 May 12, 2009 08:34 AM
Videocard does'nt seem to fit issamhay Troubleshooting 14 May 11, 2009 12:46 PM
How to test a used videocard? pp1111 Troubleshooting 10 April 21, 2009 03:19 PM
What do you all use to stress test your Videocard? Gameplaywarrior Overclocking, Tweaking and Benchmarking 5 October 11, 2008 02:12 PM
