Old January 15, 2010, 07:00 PM
martin_metal_88's Avatar
Default -bigadv bonus in FAHMON
Hey guys, I finally do my 10 normal WU's and now I just start my -bigadv and it work but now I want to know if it's possible to show the bonus in fahmon because basically it seems to not. If yes then...how? FahMon was set to work with the IP of the VM there is no more to do I think but maybe I'm wrong. If FahMon can't show them then which software will?
Thx guys!
Ask for more
Martin_metal_88
Colenzo : See system spec!
Odysseus : I7 860 @ 3.6Ghz || GA P55-UD5 || G.skill Ripjaws F3-16000 2000Mhz 2X2GB || Coolermaster ATCS 840 || Silverstone Strider plus 850W || WD 640 black - WD 1TB green - Samsung F3 2TB || MSI 5670 1GB Cyclone ||Coolermaster Hyper 212 + ||
Old January 15, 2010, 07:03 PM
SugarJ's Avatar
Fahmon does not show the bonus, but hfm.net does. hfm-net - Project Hosting on Google Code
Sagath's Avatar
Thx guys!
No, you cant, as far as I know. The bonus is calculated on how fast you complete the WU. So someone that does it faster, will get a larger bonus.
The formula for calculating this is on the FAH forums if you look for it. I think its on ours somewhere too.
Old January 15, 2010, 07:34 PM
Great it work well for the CPU but can't set up my GPU to work with. I am trying to figure out but if you have some advice;)
Thx
Ask for more
Martin_metal_88
Old January 15, 2010, 07:36 PM
SugarJ's Avatar
you can import your fahmon config file, and it will pick up all your clients automatically.
Old January 15, 2010, 07:37 PM
Ok my bad I just noticed that I was using the wrong directory now everything is working fine! let's see about these bonus thx sugarJ !!!
Ask for more
Martin_metal_88
Old January 15, 2010, 07:39 PM
SugarJ's Avatar
No problem. It calculates the bonus for you based on your time per frame. Your PPD for that client will include the bonus if eligible. You may have to force it to download the new projects for it to show up.
Old January 15, 2010, 08:50 PM
So it will show the bonus at the end of the WU if I understand.
Ask for more
Martin_metal_88
Old January 15, 2010, 09:59 PM
SugarJ's Avatar
It projects your PPD including the bonus based on your TPF.
In the screenshot below, you can see my PPD and projected credit based on the current TPF. Fahmon shows the PPD without the bonus, which would be about 9500 PPD for this unit. However, I never get that exact credit, because it takes 25 minutes to upload the work unit when complete.
Anyway, I've completely switched away from Fahmon.
Old January 16, 2010, 08:01 AM
Arinoth's Avatar
The latest version of Fahspy will also let you know how much you'll be getting with the bonus as well.
Setting -bigadv martin_metal_88 HardwareCanucks F@H Team 37 January 11, 2010 08:10 PM
SMP2 Core Progress Update - Some Will Have Bonus Plan LCB001 HardwareCanucks F@H Team 85 December 15, 2009 01:33 PM
cant get fahmon to work. kyle_L HardwareCanucks F@H Team 7 April 23, 2009 07:46 PM
FAHMon and F@H set up reccomendations CasheKicker HardwareCanucks F@H Team 36 February 22, 2009 04:57 PM
FS: CIB, Motorola K1 KRZR Project (RED) Edition, Bonus Bluetooth HS ~ $150 compRSP Buy/Sell & Trade 2 February 27, 2008 04:54 PM
