Originally Posted by Scratch Well to say the least I find all of this quite confusing. I ran a VMWare server with linux and FaH back when I had an AMD 2x64 3800+ rig 3 years ago and I didn't find it to work well at that time although I found it easy to setup
This time however I am having problems. For some reason VMWare tools was not installed or is not working with my server and I am unable to find a way around it. It keeps saying "VMWare Tools cannot be installed with this guest operating system" So unless there is an uncomplicated fix I will be returning to a normal SMP tomorrow |
Are you trying to install vmware server v1.0.3? if so, it fails on most of my rigs.
However, v 1.0.2 installs and works fine.
As 3.0C said, ignore the vmware tools not installed message even on v 1.0.2 Everything works fine without it.
I think those tools are intended for use in a remote admin scenario for real servers ... and you don't need them since you have direct control on your desktop. One of the things it needs if you do want to try using the tools is to have iis installed. I never bothered with it.
Is that the only reason you were going to switch back to the native win smp client? Or do you find it causes you usability problems on windows with other apps? Have you tried tuning the memory usage in the host and vm settings, or adjusting the priority on the vmware-vmx.exe tasks?
I am curious to learn what your experiences are.
It wasn't entirely clear in your post if you are having install problems, or execution problems.
