Old January 11, 2010, 05:06 PM
Default Help setting up 3x GTS 250s
All ready to go. I realized I won't be able to put 4x GTS 250s like I wanted to. The last one hits the support "beam" on my Highspeed Tech Station and won't fit. So 3x it is for now.
XP 32 is set up. I haven't downloaded/installed the GPU drivers yet. Should I do it with just one card to start and then after reboot add another and so on?
"What is the colour when black is burnt ?" - Neil Young
Old January 11, 2010, 05:10 PM
Perineum's Avatar
Install the driver and it should do for all 3, then install FAH
Old January 11, 2010, 05:26 PM
3.0charlie's Avatar
Back when I had my HSPC set up for 4 GPUs... exactly what you want. Easy to do. Look at the right post. You won't be ablt to use the crossbar, but with 4 GPUs they are going nowhere.
edit: or set up above...
Old January 11, 2010, 05:47 PM
Never thought of that. I think I'll do like your bottom picture. Do I need to do dummy plugs?
Old January 11, 2010, 05:48 PM
sswilson's Avatar
Best way to do it (IMO) is to install one card first with the drivers, then install FAH with just the single card installed.
Once that's up and running, copy the fah folder for each of the extra cards (you'll need the -gpu0, gpu1, gpu2, etc.... switch for each one... there's a thread here with links to the best way to set it up), and then physically install each extra card individually to allow windows to install the drivers. Under XP32, if you install each one individually, you'll only need one extra monitor hookup (the second VGA on an lcd monitor works fine) to allow you to "extend the desktop" and once it's set you can disconnect the vga connection for the next card. If you do it this way you won't need dummy plugs.
For day to day operation, I've got a folder on my desktop with icons listed as GPU1, GPU2, etc..... for starting the individual FAH instances.... I prefer doing it manually on each startup so that I know for sure which taskbar icon corresponds to which physical card.
Old January 11, 2010, 05:54 PM
MarkOne's Avatar
Why Charlie put 8 dummies , 1 for each card is not enough ? or you can start 2 client per card ?
Old January 11, 2010, 06:09 PM
I think it has to do with the cards he had in there.
Ok I will give it a try.
Old January 11, 2010, 06:13 PM
Not if you're using XP.
Old January 11, 2010, 06:17 PM
And once I set it up properly ( I hope !!! ) I won't need a 2nd monitor right ?
Need help setting VM Folding doup93 HardwareCanucks F@H Team 6 April 27, 2009 05:27 AM
little help setting up please marcons HardwareCanucks F@H Team 1 April 17, 2009 11:56 AM
Need help setting up my raid. sheepdogexpress CPU's and Motherboards 9 March 27, 2009 10:50 AM
Fatal1ty setting Computergeek Audio 2 July 3, 2008 06:04 PM
Best setting for E6600 Digital_Fortress Overclocking, Tweaking and Benchmarking 0 April 23, 2008 10:44 PM
