  #31 (permalink)
Old January 18, 2010, 01:05 AM
Originally Posted by sswilson View Post
Did you "extend" the desktop?
Forgot to mention its on a different rig than the 250 GTSs.
"What is the colour when black is burnt ?" - Neil Young
  #32 (permalink)
Old January 18, 2010, 01:07 AM
In Fahmon I get this error: FAHlog.txt does not exist
  #33 (permalink)
Old January 18, 2010, 01:59 AM
Originally Posted by crazyhorsejohnny View Post
I just installed a 240 GT and none of the monitoring programs seem to work with this GPU yet. Unless I'm missing a step.
as in fahmon or you cant monitor temps and such..try precision, everest.
  #34 (permalink)
Old January 18, 2010, 05:53 AM
Fahmon and others. Would like to know PPD.
  #35 (permalink)
Old January 18, 2010, 09:47 AM
Have you confirmed that the client is actually running? If there's no FAHlog.txt, chances are you're not even folding successfully.
  #36 (permalink)
Old January 18, 2010, 11:39 AM
10e's Avatar
10e 10e is offline
There absolutely has to be a FAHLOG.TXT (as Zero82z has mentioned) for FAHMON to recognize and report it. If you double click on the client in FAHMon it will bring up the actual work directory you are monitoring, and you can manually check if there is a FAHLOG.TXT file there. If there isn't something is very wrong, because even if you get UNSTABLE_MACHINE errors, or other core problems, a FAHLOG.TXT file is always generated.
If it's not there, then try running the client manually and see what happens.
  #37 (permalink)
Old January 18, 2010, 12:24 PM
LCB001's Avatar
Folding Captain
You might want to check which folder you have FahMon pointed at.
I don't use FahMon but in HFM.net and FahSpy it's the main client folder, not the work folder itself...
Folding For Team 54196
  #38 (permalink)
Old January 18, 2010, 02:49 PM
That was it.
Need help setting VM Folding doup93 HardwareCanucks F@H Team 6 April 27, 2009 05:27 AM
little help setting up please marcons HardwareCanucks F@H Team 1 April 17, 2009 11:56 AM
Need help setting up my raid. sheepdogexpress CPU's and Motherboards 9 March 27, 2009 10:50 AM
Fatal1ty setting Computergeek Audio 2 July 3, 2008 06:04 PM
Best setting for E6600 Digital_Fortress Overclocking, Tweaking and Benchmarking 0 April 23, 2008 10:44 PM
