  #21 (permalink)
Old January 13, 2010, 11:43 PM
I gave it a good 24hrs+ and I was lucky to get 5200 PPD for 353s with my 2x GTS 250s (on same board). And that was for both. Meanwhile I have a 9800GTX+ (by itself) folding on my wife's rig and the PPD for 353s was 6630.
But then a funny thing happened. I installed Boinc/Rosetta and now the PPD for my GTS 250s is now 6630 just like the 9800GTX+. Go figure.
"What is the colour when black is burnt ?" - Neil Young
  #22 (permalink)
Old January 13, 2010, 11:47 PM
sswilson's Avatar
Heh.... that's pretty bizarre.... wonder if it was a priority/affinity issue that ended up being re-assigned once you installed boinc?
  #23 (permalink)
Old January 13, 2010, 11:53 PM
Even though I know that folding with nvidia cards barely uses CPU time compared to ATI cards, I waited to install Boinc cause I wanted to see what kind of PPD I'd get just folding and not touching priority/affinity.
So I install Boinc and PPD goes back to normal.
  #24 (permalink)
Old January 14, 2010, 12:11 AM
LCB001's Avatar
Folding Captain
Did you check to make sure you changed the priority from idle to low on All the gpu clients when doing the config, it can be an easy thing to miss. If you missed one of them it might give those results.
Boinc will normally drop it's own priority when other DC clients are also installed...
Folding For Team 54196
  #25 (permalink)
Old January 14, 2010, 12:25 AM
- Core Priority I checked "Slightly higher...."
- CPU Usage Percent I put it at 100%
- Priority at High in Windows Taks Manager
These settings don't seem to be affecting Boinc as Poem and Rosetta are flying (30min elapsed-30% progress)
  #26 (permalink)
Old January 14, 2010, 12:55 AM
LCB001's Avatar
Folding Captain
Not sure what it could have been then.
Boinc has always played nice with my gpu's so I've never bothered adjusting the priority in task manager, it's something Stanford could learn from.
Ever thought of Crunching for Us...
  #27 (permalink)
Old January 14, 2010, 06:33 AM
Just might. I have 2x 955BE, wife's E6850 and son's E5300.
  #28 (permalink)
Old January 17, 2010, 11:06 PM
LCB001's Avatar
Folding Captain
It would be great if you did, our smaller Teams certainly could use the help.
There is lots to choose from; Rosetta, Poem, Seti and WCG...
  #29 (permalink)
Old January 18, 2010, 01:01 AM
I just installed a 240 GT and none of the monitoring programs seem to work with this GPU yet. Unless I'm missing a step.
  #30 (permalink)
Old January 18, 2010, 01:02 AM
sswilson's Avatar
Did you "extend" the desktop?
Need help setting VM Folding doup93 HardwareCanucks F@H Team 6 April 27, 2009 05:27 AM
little help setting up please marcons HardwareCanucks F@H Team 1 April 17, 2009 11:56 AM
Need help setting up my raid. sheepdogexpress CPU's and Motherboards 9 March 27, 2009 10:50 AM
Fatal1ty setting Computergeek Audio 2 July 3, 2008 06:04 PM
Best setting for E6600 Digital_Fortress Overclocking, Tweaking and Benchmarking 0 April 23, 2008 10:44 PM
