Old January 11, 2010, 07:20 PM
3.0charlie's Avatar
Needed the plugs because I was folding with 4 9800GX2s in Vista. Only way I managed 8 Clients at once.
Hydro-Quebec is salivating...
Old January 11, 2010, 07:22 PM
sswilson's Avatar
Originally Posted by crazyhorsejohnny View Post
And once I set it up properly ( I hope !!! ) I won't need a 2nd monitor right ?
That is correct. If you've got an lcd with two inputs you don't even need a second monitor for setup. The second input is sufficient.
Right.
Old January 11, 2010, 07:34 PM
Soultribunal's Avatar
Make sure because nVidia is wierd sometimes that multi-Gpu Support in the control panel is disabled. When I folded with twin GPUS first time a year ago that was my roadblock before I got them folding.
And I own two of those cards now 3.0 hehehehehehe god I wish I had you Tech Station like that.
ST
www.realhardwarereviews.com
Old January 11, 2010, 07:38 PM
MarkOne's Avatar
Ok, 3.0 if I understand well, it's because they are dual GPU , right
Old January 11, 2010, 07:43 PM
Arinoth's Avatar
Originally Posted by Zero82z View Post
Not if you're using XP.
Don't need it in Windows 7 either if you use the same force flags that you use for sli-ing
-forcegpu nvidia_g80 -gpu 0
-forcegpu nvidia_g80 -gpu 1
-forcegpu nvidia_g80 -gpu 2
and just make sure they have their own directories (in user\roaming\etc)
Here I am: here I remain
Old January 12, 2010, 06:52 AM
I got 2x of them setup. Ran pretty good overnight with ok temps. With fans at 60%, GPU closest to 212+ had temps between 57 and 67. The other one between 52 and 62. I'll add more cooling probably to help them out. Now what concerned me a bit is the PPD. Both are currently doing 353s andd the PPDs are 5083ppd and 4999ppd. YThat seems a bit low even for stock (Core:756 Shader:1836 Memory:1100). When folding individually (stock) PPD for 353s was closer to 6000ppd. Any ideas?
"What is the colour when black is burnt ?" - Neil Young
Old January 12, 2010, 07:39 AM
sswilson's Avatar
Does seem a bit low, but the latest batch of 353's I've been getting seem to have a few duds in them (had two running on identically clocked cards and they were over 200 PPD apart) so that might have something to do with it.
  #19 (permalink)
Old January 12, 2010, 11:03 AM
Ok I'll watch them closely.
  #20 (permalink)
Old January 12, 2010, 11:15 AM
There are some bad 353's circulating right now. I had 3 tank my GX2's PPD by almost 1000/card.
Don't worry about it too much unless it becomes consistant.
ST
Need help setting VM Folding doup93 HardwareCanucks F@H Team 6 April 27, 2009 05:27 AM
little help setting up please marcons HardwareCanucks F@H Team 1 April 17, 2009 11:56 AM
Need help setting up my raid. sheepdogexpress CPU's and Motherboards 9 March 27, 2009 10:50 AM
Fatal1ty setting Computergeek Audio 2 July 3, 2008 06:04 PM
Best setting for E6600 Digital_Fortress Overclocking, Tweaking and Benchmarking 0 April 23, 2008 10:44 PM
