  #21 (permalink)
Old January 11, 2010, 02:06 PM
martin_metal_88's Avatar
Ok I think I catch up everything! I will let it pass 10X normal WU's before to do it again only to be sure.
  #22 (permalink)
Old January 11, 2010, 02:11 PM
lowfat's Avatar
Originally Posted by Arinoth View Post
We're you using just 1 client folding on all 7-8 cores for that month? If it was 2 clients or if you didn't have the smp 7 (or 8) flags it doesn't count. It essentially needs to get 10 completed regular work units in within 4 days in order for you to get the bonus, which is only possible on 7-8 cores (depending on the OC) not 2 vmware clients folding at the same time.
I don't think that is correct. I never used more VMware w/ more than 2 cores per client. before the bigadv. I still get my bonuses.
Mael
Big Lian Li
Forever Alone
  #23 (permalink)
Old January 11, 2010, 02:31 PM
3.0charlie's Avatar
Originally Posted by MarkOne View Post
WTF...En corp love me, you want to kiss Charlie.. on a l'air d'une belle gagne de ...... ( We look like a bunch off. )
... de moumounes?
Back on topic. You can have as many VMs to fold the 10 WUs, but you have to use the -advmethods flag. Once the 10 WUs are folded, you replace the -advmethods flag by the -bigadv flag.
-smp 7 or 8, it don't matter.
Hydro-Quebec is salivating...
  #24 (permalink)
Old January 11, 2010, 02:48 PM
MarkOne's Avatar
Just a slightly OT question. I try to fallow here, is this 7-8 refer to the treads ? , you count the 4 hyper treading, ? with the virtual client, you not suppose to use 1 client per 2 real cores ?
  #25 (permalink)
geokilla's Avatar
If you already folded 10 A2 WU (doesn't matter when or client) with the passkey, then you can go fold the -bigadv WU.
Also download the latest image, maybe even the one that's currently in development, and configure the client using the web. I found it much easier to configure and really simple to do.
@Mark. On Core i7 with HT enabled, there's 4 cores and 8 threads. Reason be is because HT creates 2 threads in one core.
  #26 (permalink)
Old January 11, 2010, 02:49 PM
Arinoth's Avatar
Yes it refers to the threads, 4 logical, 4 hyper threading = 8 threads.
Here I am: here I remain
  #27 (permalink)
Old January 11, 2010, 03:06 PM
MarkOne's Avatar
I must have not ask properly,( I guess I know that a I7 have 4 hyper treading. ) it's just than usually we count only the core not the tread, it's funny for me I will have thing than folding will work better with hyper treading disable .... in the time of the old PIV, If I remember well encoding was faster with hyper disable. May be it's just my memory who is getting not better than my eyes
  #28 (permalink)
Old January 11, 2010, 04:19 PM
... de moumounes?
-advmethods is the thing I had in the shortcut right? but using VM there is no shortcut???I don't know if it's because I'm french or because I don't know enough about folding and setting VM and thing like that but all the setting thread for -bigadv and most of what you are telling to me here I don't really understand. What is the -advmethods flag and where do I ad it???
  #29 (permalink)
Old January 11, 2010, 05:06 PM
3.0charlie's Avatar
The Vm you are probably talking about (in which you cannot add any flag) is the notfred vm. You need the specific linux client which allows for bigadv WUs, which also uses VMware Player.
For bigadv WUs, follow this great guide (use V0.6): VMware 3.0 && bigadv folding
Start with the -advmethods flag for 10 WUs WITH a passkey, then replace the flag with -bigadv.
  #30 (permalink)
Old January 11, 2010, 05:45 PM
This guide is the one I used to set my VM but I still not understand what is the -advmethods there is no place in the guide where it talk about it. When you open the VM it offer you to enter
Username : fah
Password : fah1234
key : the thing stanfort provide
then enter in the root thing : .fah6 -smp 8 or .fah6 -bigadv -smp 7 or 8
then set all prefered setting am I right?
Setting FAH martin_metal_88 HardwareCanucks F@H Team 6 September 28, 2009 08:16 PM
Need help setting VM Folding doup93 HardwareCanucks F@H Team 6 April 27, 2009 05:27 AM
little help setting up please marcons HardwareCanucks F@H Team 1 April 17, 2009 11:56 AM
Need help setting up my raid. sheepdogexpress CPU's and Motherboards 9 March 27, 2009 10:50 AM
Best setting for E6600 Digital_Fortress Overclocking, Tweaking and Benchmarking 0 April 23, 2008 10:44 PM
