  #21 (permalink)
Old January 11, 2010, 06:40 PM
Originally Posted by Jake_HT View Post
From nvidia site, each GTS 250 draws a max of 150W.
4x 150W = 600W..
500 is enough?
I too am going to say 850W. 750W being borderline. 500? Nope! Not for me...
The TDP numbers given by ATI and nVidia for their video cards are generally quite conservative. With that said, 500W would not be enough for a system like this to run comfortably, if even at all.
Originally Posted by Soultribunal View Post
Putting a PSU that close to its Peak Output is asking for trouble no matter what.
It would be the PSU's continuous output rating, not its peak rating (good PSUs are rated based on continuous, not peak output). But you are correct. Running a PSU outside of its peak efficiency zone (generally 40-60% load, although most good PSUs can be run up to 80% or so without difficulty) will result in lower efficiency, higher temperatures, worse performance, and a shortened lifespan.
  #22 (permalink)
Old January 11, 2010, 06:51 PM
Soultribunal's Avatar
I am going on what would be peak for a 500W Zero, or most peak anyways. My Silverstone for example is rated for a continuous output of 750W with a peak of 800W. I was saying if by some chance that setup worked it would be right at the peak output of a said good quality 500W supply.
Hence my suggestion for the Silverstone Strider Plus.
REgards,
ST
www.realhardwarereviews.com
  #23 (permalink)
Old January 11, 2010, 06:56 PM
sswilson's Avatar
I think it's also worth mentioning that this is for a folding rig that will be running full tilt 24/7.
Even the continuous rating on a quality (realistically rated) PSU can't be expected to reflect 24/7 non-stop operation at 80%+ of it's rated output. I'm currently looking at my 750W silencer and wondering if I should upgrade it for the 4X 9800GT cards. (It's not running hot, but it is running warm).
  #24 (permalink)
Old January 11, 2010, 06:58 PM
Nope, it's plenty. I know people who have run three and four 9800GX2s off of TX750s.
  #25 (permalink)
Old January 11, 2010, 07:01 PM
3.0 CHarlie Ran 4 GX2's off of his 910 Silencer. You are okay, I would only worry if you had 4 x First Gen 9800GTX+ because those were power hungry. The GT's are not.
ST
  #26 (permalink)
4 gx2's? hmm..i know it can do the watts, but the amps...
  #27 (permalink)
Old January 11, 2010, 07:04 PM
Watts and amps are two sides of the same coin as far as we're concerned here.
  #28 (permalink)
Old January 11, 2010, 07:05 PM
was actually wondering about the numbers. each gx2 does something like..hmm...
9800 GX2_____________########¦)#¦]##########}| 69W-83W-182W ²
  #29 (permalink)
Old January 11, 2010, 07:11 PM
We've already established that the power numbers from that link you are using are not at all reliable.
  #30 (permalink)
Old January 11, 2010, 07:16 PM
show me some numbers then. what is your pc with 3 gx2's pulling at the wall?
unsure of power needed for next gen upgrade dinmaster Power Supplies 10 November 10, 2009 02:16 PM
[WTB] Power supplies needed yamawho Buy/Sell & Trade 4 February 24, 2009 01:35 PM
1KW Power Supply Needed.... mlauzon Power Supplies 11 December 23, 2008 05:48 PM
