  #21 (permalink)
Old October 25, 2007, 02:48 PM
stoanee's Avatar
Well, actualiy, I am folding for the NCIX team right now. Hardware Canuks would be my second choice though. How is the Canuk team doing anyway?
heatware
  #22 (permalink)
Old October 25, 2007, 05:33 PM
3.0charlie's Avatar
We're a relatively small Team compared to NCIx, and we are ranked ~470 ATM. We need all the members we can to help us move forward!
Hydro-Quebec is salivating...
  #23 (permalink)
Old October 25, 2007, 05:34 PM
Cptn Vortex's Avatar
I may consider folding again, so long as my power bill doesn't get too rediculous.
The Vortex H20
Corsair Obsidian 500D
Asus X99-E WS
i7-5820K @4.4GHZ
RTX 2070
4x4GB Corsair LPX 2666MHZ
Thermaltake Toughpower 850W GOLD
960GB ADATA SX8200 NVME
HP OMEN 32 1440p 75hz
Benq W1070 Pojector.
Watercooling:
EK Supreme HF, EK Vector RTX2080 FC, EK Coolstream XT 220 Rad, MCR320 Rad, EK-XTOP SPC-60 Pump, EK Multioption 100ml Res
  #24 (permalink)
Old October 28, 2007, 01:53 AM
Apollo4g's Avatar
Hey all, well i finished a few units but it gives me some errors saying it cannot send the results to the server.
What can i do?
It has tried a few times but keeps saying retrying....
Wow this sux seems my units i did before did not send either, and it says unit deadline passed, hmmmm
someone please help.
My pleasure, but I didn't do too much...
To benchmark your folding, d/l Fahmon (Home | FahMon). It will give you the folding ppd (points-per-day) average. I'll know then if your crunching #s are good, compared to my Q6600. You can also add your lappy's E6600 to Fahmon if you have a network. Then we could do the same comparison with my E6400 which is folding @ 3.43GHz.
Your E6600 will be running @ 3.6 in your lappy?
Sorry for the late reply, nope, my lappys max oc is 2.9 . But i might put it in a new desktop and crank it up to 3.6 again.
Put some cooler in my lappy :)
Hmmmm so can anyone help with my problem?
Oh can someone please tell me what to select for the advanced options?
Do i say yes for "use internet explorer setting?"
Also i added the program to my exceptions on my firewall, im getting the packets and downloading them so i dont think thats the problem.
Anyway please help soon, dont want the packet i just did to expire as well :(
Originally Posted by pscout View Post
The supported way to look at your client.cfg settings is to run the clinet with the '-configonly' flag. It will display current or default settings, whatever is currently set and you can change them if you need to ... with -configonly the client ends after the config prompts without downloading a new wu or starting an existing one so you can run it as often as you need to but you can only have 1 client running at a time in a directory and with its own machine id (which is the last prompt under advanced setting prompt).
Also how to i setup a '-configonly' flag?
I dont know what you mean by that,(sorry for my noobness at this!) and i need to edit my advanced settings.
Im using th SMP client btw :)
UPDATE:
Alright opened it with noteTab and i have this:
[settings]
username=apollo4g
team=54196
asknet=no
bigpackets=yes
machineid=1
[http]
active=no
host=localhost
port=8080
usereg=yes
Where is the advances setting? LoL
What values should i change for max results and fixing this dam thing so i can send my results.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
  #25 (permalink)
Old October 28, 2007, 11:21 AM
stoanee's Avatar
Well, I certainly am not an expert but......I believe that as long as the units were crunched in time that you will be credited when you finally upload them. (don't quote me on that one though). I know that some folding servers have issues sometimes and do not upload for a while. Are the wu's still sitting in your queue? I have had to shutdown my folding and restart sometimes to force the wu to send. You could ask for advice on the NCIX forum, there a quite a few knowledgeable people there. *from NCIX forum*Quote-If you shutdown the SMP client (and wait a minute for all the threads to stop), you can force send it by typing (in command/dos window) the name of smp client with the parameters -send all -verbosity 9 (verbosity 9 to give more info on what is happening). It can take up to 15 minutes for that to complete.
heatware
  #26 (permalink)
Old October 28, 2007, 01:16 PM
Apollo4g's Avatar
Thanks for the info, i tried to restart it, but still nothing.
Where do i type those dos commands in? I cant type anything in the F@H dos window.
  #27 (permalink)
Old October 28, 2007, 07:51 PM
stoanee's Avatar
Are you running vista?
Here is a link hope it helps. I am out of town right now so I can't jump onto my quad to check things out
Folding@Home SMP Console Install - DigiWiki
heatware
  #28 (permalink)
Old October 28, 2007, 08:03 PM
Apollo4g's Avatar
nope xp 32
  #29 (permalink)
Old October 29, 2007, 05:29 AM
3.0charlie's Avatar
Make sure you follow these steps (except for the username and team number and "Allow receipt of work assignments...: choose Yes), they should answer your questions related to the install. And yes, the F@H servers have been acting lately.
Do not use IE settings.
Do not proxy.
Use maximum memory available.
John
  #30 (permalink)
Old October 29, 2007, 07:59 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Follow this procedure if you are having issues sending completed units to server:
http://www.hardwarecanucks.com/forum/24265-post3.html
Fs Quad Core Q6600 elec999 Buy/Sell & Trade 10 January 26, 2008 09:02 PM
Dual or Quad?? BALISTX CPU's and Motherboards 4 November 22, 2007 01:36 AM
Why do You Fold? Supergrover HardwareCanucks F@H Team 4 August 28, 2007 05:02 PM
C2D vs Quad vs Xeon enaberif CPU's and Motherboards 9 August 9, 2007 10:40 PM
Quad Kore Masters Shredder Troubleshooting 3 March 21, 2007 08:42 PM
