Old October 21, 2007, 03:09 PM
Fallen Folder
Originally Posted by Apollo4g View Post
Pscout could you link me to the exact standard clients (text only) you are talking about.
How do i know im running big packets?
It is the second one showing on the top of the download page
"Windows NT/2000/XP/Vista text-only console (with built-in Windows-service-install option)"
link: http://www.stanford.edu/group/pandeg...04-Console.exe
The first time you run the client you will configure it and when it asks for "accept receipt of work assisnments and return results > 5 MB " answer 'yes'.
You can also look at the client.cfg you have with notepad (free notetab is better since it handles unix formatted files properly) and it should have a line "bigpackets=yes". DO NOT Open/save with Wordpad ... it WILL CORRUPT THE FILE and the client will run with all defaiult values including username and team #.
The supported way to look at your client.cfg settings is to run the clinet with the '-configonly' flag. It will display current or default settings, whatever is currently set and you can change them if you need to ... with -configonly the client ends after the config prompts without downloading a new wu or starting an existing one so you can run it as often as you need to but you can only have 1 client running at a time in a directory and with its own machine id (which is the last prompt under advanced setting prompt).
Old October 23, 2007, 09:32 PM
Apollo4g's Avatar
Alright well set up a password and im using the SMP client now, its stressing my quad at 100%!!
HardwareCanucks F@H Team just got a little more kick
LoL thats stuff is too complicated for me pscout!
However i did say "yes" to the 5 MB assignments :)
Just didnt do any of those things with the config file, im scared ill mess it up.
800D | i7 920 | EVGA Classified LE | 5970 EK Waterblock | 12GB - 1600 Dominators DDR3 | Silverstone Decathlon 1200W | Vertex 120GB |
ASUS Xonar HDAV1.3 | Heatkiller 3.0 | Thermochill PA.120.3 | Freezone Elite | 2x655's with EK Dual D5 Top | T-Virus Res |
Old October 24, 2007, 05:24 AM
Fallen Folder
You should start to see some very nice points production now
Old October 24, 2007, 05:42 PM
Apollo4g's Avatar
Hey guys i did a 500,000 fle in about 12 hours. Its now working on a 1,000,000 size file.
My quad at full 100% load overvlocked at 3.6 gives me load a temperature of about 50C .
Got to love watercooling :)
Old October 24, 2007, 05:48 PM
3.0charlie's Avatar
Yup, the Q6600 oc'ed is a monster in folding. I have mine running 2 Linux distros with each their own F@H console... about 4400ppd. On a single CPU! But as you stated, water is a must.
John
Hydro-Quebec is salivating...
Old October 24, 2007, 06:11 PM
Apollo4g's Avatar
Yup :)
Are my rates good?
I'd like to thank you Charlie for the help you have given me in setting up my F@H :)
Hopefully ill get my E6600 rinning at 3.6 to help out
Its in my laptop so heat is a real issue
Old October 24, 2007, 06:22 PM
3.0charlie's Avatar
My pleasure, but I didn't do too much...
To benchmark your folding, d/l Fahmon (Home | FahMon). It will give you the folding ppd (points-per-day) average. I'll know then if your crunching #s are good, compared to my Q6600. You can also add your lappy's E6600 to Fahmon if you have a network. Then we could do the same comparison with my E6400 which is folding @ 3.43GHz.
Your E6600 will be running @ 3.6 in your lappy?
Old October 25, 2007, 11:15 AM
Fallen Folder
The key number to look at when assessing folding performance is the project number ie. 2651/52/63, 2605, 304x/305x are most, if not all the smp project #'s atm. Each project # has its own points level.
The number of steps per wu will not usually uniquely identify the project # that the wu is part of.
Here is a link to the current project summary page at stanford which list all current public projects being assigned to all current client types:
Folding@Home
  #19 (permalink)
Old October 25, 2007, 12:27 PM
stoanee's Avatar
So far I am getting about 1300 ppd with my stock Q6600 (B3) using the SMP client.. I would love to get 4000 ppd but my kids use the computer too so I have to keep it turned down. When I get another video card I will ditch the ASRock mobo and get something I can OC with. Hopefully my production will increase also.
heatware
  #20 (permalink)
Old October 25, 2007, 12:55 PM
3.0charlie's Avatar
What's your F@H id? Because you can have your F@H tag (just like mine under my forum name) if you have submitted you first WU for the team . As for 4000ppd using a Q6600, you need to OC that Quad to reach that...
John
Fs Quad Core Q6600 elec999 Buy/Sell & Trade 10 January 26, 2008 09:02 PM
Dual or Quad?? BALISTX CPU's and Motherboards 4 November 22, 2007 01:36 AM
Why do You Fold? Supergrover HardwareCanucks F@H Team 4 August 28, 2007 05:02 PM
C2D vs Quad vs Xeon enaberif CPU's and Motherboards 9 August 9, 2007 10:40 PM
Quad Kore Masters Shredder Troubleshooting 3 March 21, 2007 08:42 PM
