Originally Posted by _dangtx_ ok. now we need pics, and maybe 4x120mm fans strategically palced to help with the airflow. |
Heh.... already had to place one. GPU1 (first inside gpu) was running a 10101 at around 90c!!! the backside on it was freaking hot!!!! slapped a scythe in directing air across it which dropped temps by a good 10c+. It even dropped the temps on the second GPU by a fair bit (wicking away heat from the heatsink side which removed some sympathetic heat generated on the second card).
Only card that's currently worrysome is the third in the series.... no real way to affect temps on that one over and above the fans I have drawing heat away like the previous cards.
The fourth card in line (cooler open to air) runs 20c+ cooler than the other 3.
Originally Posted by Supergrover I think most of the "old School" overclockers go this route, I know I do.
Looks l8ike some nice PPD per Buck.
I agree whats the point of going with used cards when the price is so close to on new. Do you have it setup in your Tech station? |
Yep, sitting on my techstation. I'll post up some images once I get the fan placement figured out. I was actually a bit surprised.... these GTs are actually a bit shorter than the GSOs were.
