Old December 22, 2009, 06:45 PM
Soultribunal's Avatar
Default 353 Issues
Anyone else notice a Major Drop in PPD with these guys?
My GTX260 MATRIx has been spending 6 hours on one and its clocked in fine.
My GX2 and 9800GT are both way down what they should be as well.
Or am I the only one who got a bad batch?
ST
www.realhardwarereviews.com
Old December 22, 2009, 06:46 PM
sswilson's Avatar
I'll check, but when I looked earlier this evening all I had were 1888 WUs.
Old December 22, 2009, 06:47 PM
3.0charlie's Avatar
There were always bad batches of the 353s... delete the queue, the Work folder and start over.
Hydro-Quebec is salivating...
not at all. between the several flavours of 353 ppd'ers can vary a good few k's on higher end cards :)
Old December 22, 2009, 06:51 PM
sswilson's Avatar
Just pulled a 353 on my 275 but it's only currently at 1%. I'll let you know in 15 minutes what it's putting out.
Old December 22, 2009, 06:53 PM
set fahmon at last 3 frames.
Old December 22, 2009, 06:54 PM
sswilson's Avatar
Nope..... 5771 (R8, C231, G944) putting out my typical 9200+ for a 353.
Are you running a "all core" smp client on that? Any chance it's taking up more than normal resources?
Old December 22, 2009, 06:57 PM
I haven't changed a thing and one Rig was putting out 10k the other 12K...now they are both stalled on the GPU side.
Wonder if its this new Uni-Core out.
ST
Old December 22, 2009, 07:00 PM
Buck Nasty's Avatar
Check your priority/affinity's for the GPU2 cores. I have had several GPU2 cores hanging to a single core of the CPU with a low priority as of recently.
Old December 22, 2009, 07:11 PM
Clear your queue, get a new unit. If you're still having trouble after that, then it's on your end. I've gone through a bunch of 353s today and all of them ran fine.
monitor has some issues Bubbzilla Troubleshooting 2 November 22, 2009 09:45 PM
anyone having issues with teksavvy? _dangtx_ Off Topic 21 November 7, 2009 10:48 PM
353 pointers failing on GTX260 Perineum HardwareCanucks F@H Team 31 October 17, 2009 08:57 AM
Pump Issues Exmortis Water Cooling 7 December 28, 2008 05:04 PM
e8400 issues enaberif CPU's and Motherboards 5 February 15, 2008 02:13 PM
