Old December 21, 2009, 10:08 AM
Shadowmeph's Avatar
Default is there a special way to asetup my GPU for folding?
I finally installed my bfg285GTX and want to start folding ( again) but I am not sure how to set up so that the GPU is doing the work.
Old December 21, 2009, 10:38 AM
Soultribunal's Avatar
All you need to do for a Single GPU is go to stanfords F@H website and download the highperformance GPU Client for it. Then run the installer and configure it for your name and team 54196. Voila! Folding on GPU!.
ST
www.realhardwarereviews.com
Old December 21, 2009, 12:22 PM
Here is the link to the specific client you need: http://www.stanford.edu/group/pandeg...ystray-623.msi
Old December 21, 2009, 11:33 PM
Shadowmeph's Avatar
Thank you
Old December 22, 2009, 05:57 AM
Buck Nasty's Avatar
Go with the Console Client. System tray is buggy and the viewer will crash an overclocked GPU.
XP Console Client
Vista/Win7 Console Client
Old December 22, 2009, 11:55 AM
The viewer is buggy, but aside from that there is no disadvantage to using the tray client. There are advantages to using the tray client as well, such as being able to pause GPU folding easily through the tray icon, view the log file through the tray icon, and reconfigure the client easily through a dialog box instead of going through the command prompt.
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 10:54 AM
OCing GPU and Folding Arinoth HardwareCanucks F@H Team 16 November 4, 2009 06:49 PM
Dual GPU Folding on one GPU (FahCore_14 only) geokilla HardwareCanucks F@H Team 2 August 8, 2009 05:35 PM
gpu folding in a wierd way, kyle_L HardwareCanucks F@H Team 8 July 15, 2009 10:46 PM
Folding with 2 different gpu's gouki HardwareCanucks F@H Team 5 July 5, 2009 01:28 PM
