Old December 14, 2009, 10:51 AM
MarkOne's Avatar
Default CPU and gpu charts
hi , where can I get a chart with the expected points for CPU and GPU
Old December 14, 2009, 11:10 AM
F@H Mon is a great tool to monitor current WUs.
Read some of stickies in this forum.
Old December 14, 2009, 11:19 AM
MarkOne's Avatar
I don't want monitor, I want to evaluate what hard ware buy, So I look for a chart with the expected points per cpu and gpu
Old December 14, 2009, 03:20 PM
bm sent me a few links...hmm....
basicaly you want 8800gt/gts g92 and up and get the shaders way up, optimally 1700 or above. on a gt that will give you roughly 5k ppd on the better wu's, 3-4k ppd on the crappier ones.
cpu wise, my q9550@3.2 is doing roughly 4-4.3 kppd . at that price you buy 2 8800gt's or gt's and double the points.
liek i say, you get yourself a nice 4 pci-e slot mobo, fill it with gt's and up, cpu can be almost anything im told. so a cheap single core or dual core will do.
Old December 14, 2009, 03:26 PM
MarkOne's Avatar
thanks but that's a recommendation ... I want charts so I can make my own one.
Old December 14, 2009, 03:30 PM
Arinoth's Avatar
There are no real charts as it varies depending on whats in a persons system and what's running. For example an i7 920 @ 3.8 GHz can do 9k ppd, it can also do 20k ppd and also 25k ppd all depending on if you are doing a normal work unit (the 9k pp), a big adv work unit with bonus and SLI folding (20k ppd) or big adv work unit with bonus and single card folding. I won't get into how the ppd can also change depending on how fast your ram is running at. The other thing also is what version and how high you can overclock your shaders on your GPUs. My GTX260s have different core and shader over clocks since they are two different base models, one gets 200 more ppd then the other.
Here I am: here I remain
Old December 14, 2009, 03:31 PM
3.0charlie's Avatar
You will only find ballpark figures.
Hydro-Quebec is salivating...
Old December 14, 2009, 03:48 PM
MarkOne's Avatar
I read something one place an I can retrieve it, they was giving exemple of the best performance vs the most econo one....
they must have a way to figure if by exemple ( and it's only an exemple) 10 PCs with e7500 with 2 gtx 260 in each will perform less or more than 2 PCs with a I 720 and 4 gtx 260 .... I know already the power usage for all those parts . So i want to figure what to buy for give me the # of points I want with the budget I want and for the ammount of power usage I want.
Old December 14, 2009, 03:50 PM
hes probably looking for something like this : F@H Stats
5/31/2009 8:50:228800 GT7589001910Vista 644726,372Heimie111065Precision182.506.23 S5900
problem is the wu can differ in the xxxx family with the runs etc. not all are the same. they are close and behave closely alike, but not the same. one can be 5kppd the other 4k ppd on the same card/cpu
and i like this one as well : F@H Stats
Old December 14, 2009, 03:53 PM
3.0charlie's Avatar
You may find performance info around the 'Net, but not what you are looking for since there are too many different WUs / hardware combos out there that will vary the ppd output.
Dazmode Provincial Watercooling Charts Dazmode Water Cooling 23 December 20, 2009 09:01 AM
[FS] CPU and GPU+FC waterblock. Lima Buy/Sell & Trade 38 August 21, 2009 12:09 AM
Folding on GPU+CPU Jonwall HardwareCanucks F@H Team 2 March 30, 2009 01:40 PM
Hardware Canucks Performance Charts Unveiled Gav Site Announcements 0 March 25, 2009 05:06 PM
Cpu, Gpu or what? upgrade? phil3_66666 CPU's and Motherboards 12 March 14, 2009 05:54 PM
