Old December 8, 2009, 05:07 AM
Default Folding with Hyper-V
Hi all,
Been trying Windows Server 2008 R2 and Hyper-V out for a while, studying for MCTS exams, and wondered if Notfred's client would run on Hyper-V. This is the end result:
The Hyper-V folders are running on a Q6600 @ 3.0 GHz with Windows Server 2008 R2 64-bits. I assigned 2 CPU's to each VM and the rig is also folding with a GTX 260 in Windows. This is how you can get it running:
1. Follow the procedure described for the VMWare clients by zlojack (Boost Your PPD with VMWare - Look inside for easy guides!) and get it running (You can't reconfigure clients on Hyper-V... Still haven't figured out why )
2. Convert to VHD using VMDKtoVHD Converter (Files: VMDK(VMWare) to VHD Converter)
3. Create a new VM on Hyper-V with no networking and use the VHD created in step 2 as Virtual hard disk
4. Go in the VM's Settings and add a Legacy Network Adapter to the VM
Et voilà
[/SIZE][/FONT]
Old December 8, 2009, 04:14 PM
LCB001's Avatar
Folding Captain
Looks interesting, is there an advantage to running it this way?.
Have you tried running all four cores in one VM?, there seems to be a decent PPD increase due to eliminating the overhead from the extra VM...
Folding For Team 54196
Old December 9, 2009, 06:27 AM
No, I haven't yet. I'll try that when I get a chance. I was just trying this out since I had Hyper-V running on it already and didn't want multiple VM software on the same rig.
[/SIZE][/FONT]
Old December 10, 2009, 05:02 PM
I did the change today to 1 VM running 4 CPU's and I've gained about 10%. Now, my Q6600 is worth about 5000 PPD.
[/SIZE][/FONT]
Old December 11, 2009, 12:16 PM
Now, I have a quick question. I've been reading everywhere about the bigadv wu: What are those? Is it worth enabling on my VM if I assign RAM to it?
[/SIZE][/FONT]
Old December 15, 2009, 05:12 PM
10e's Avatar
10e 10e is offline
BigADV is a special WU that takes a day or more to complete. Apparently it's equivalent to 10 1920 point SMP WUs.
BigAdv will only run on a machine that has enough cores to finish them in time. Generally 7 or 8 i7 cores are required, so it may not be unless you have one that can virtualize at least 7 cores under Hyper-V. An I7 has 4 physical cores with 4 virtual cores that can run parallel threads giving it 8 virtual cores in total, and that's why it's pretty much the minimum system to run BigADV.
Coolermaster Hyper 212 Plus AMD Installation & Clearance sswilson Air Cooling 64 May 7, 2011 09:33 PM
Lapping Hyper 212+ HDT hsf 0o0 Overclocking, Tweaking and Benchmarking 4 October 31, 2009 10:51 AM
Push/Pull config - Hyper 212+ Owners JMCD Air Cooling 3 October 11, 2009 09:01 PM
AMD build help (hyper 212) bumfloss New Builds 6 September 9, 2009 03:34 PM
Hyper-Threading Jake_HT CPU's and Motherboards 4 February 26, 2009 07:02 PM
