Old November 17, 2009, 10:11 PM
SugarJ's Avatar
Default Multi GPU Setup help
OK Gents,
I tried to get my "new-to-me" 8800GTS 512 up and folding.
I've got it so it starts using the -forcegpu nvidia_g80 -gpu 1 flags. Then it throws this at me:
[04:57:56] Entering M.D.
[04:58:03] Working on Protein
[04:58:04] Run: exception thrown during GuardedRun
[04:58:04] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[04:58:04] Going to send back what have done -- stepsTotalG=0
[04:58:04] Work fraction=0.0000 steps=0.
[04:58:08] logfile size=8966 infoLength=8966 edr=0 trr=23
[04:58:08] - Writing 9502 bytes of core data to disk...
[04:58:08] Done: 8990 -> 3232 (compressed to 35.9 percent)
[04:58:08] ... Done.
[04:58:09]
[04:58:09] Folding@home Core Shutdown: UNSTABLE_MACHINE
[04:58:12] CoreStatus = 7A (122)
[04:58:12] Sending work to server
Keep in mind this card folded for 3.0, so I know it's good. What am I missing? Running on Vista 64 Premium. This is in my main rig in the sig. I thought the shader bug had been fixed in the latest Fahcore.
Do I need a dummy plug?
Old November 17, 2009, 10:44 PM
to run 2 cards i had to set one as tray and the other as console. no force gpu needed. the tray one i had to put -gpu1 and also add forceasm.
edit if u have any doubt(but the nagaine its charlie here we talking about) run furmark. some dudes in here i can buy from and let the item sit months without any doubts.
AND extend desktop onto second card(but dont mess it up by making primary lol)
Old November 17, 2009, 10:58 PM
SugarJ's Avatar
It's 3.0, I KNOW this card is good.
The GTS would not start until I did the -forcegpu flag.
Going to google how to extend the desktop. That could be my problem.
Old November 17, 2009, 11:00 PM
xp : right click, properties, settings , chose card from drop down, then check the appropriate box. apply.
no need for forcegpu.
Old November 17, 2009, 11:02 PM
SugarJ's Avatar
I'm using Vista. But thanks.
Old November 17, 2009, 11:23 PM
Perineum's Avatar
With vista I extend the desktop, use a dummy plug, and just use the -gpu 1 flags
That's it....
Mind you that was 2 GTX260's on the machine I'm using now: P5Q Deluxe, Q6600, etc.
Old November 18, 2009, 12:23 AM
SugarJ's Avatar
It appears to be working now. I manually downloaded the 1.31 version of Fahcore11. I previously had 1.19. No dummy plug, no extended desktop.
Picked up hints and new Fahcore in this thread: Folding Forum • View topic - Different multi GPU configuration
Old November 18, 2009, 10:49 AM
SugarJ's Avatar
It's working great. Currently getting 8k PPD on the GTX285 and 5k PPD on the 8800GTS. And 8k plus on the new VM with the bigadv unit.
Old November 18, 2009, 10:53 AM
3.0charlie's Avatar
I'm glad to know the little card is working fine.
Hydro-Quebec is salivating...
Old November 18, 2009, 10:58 AM
SugarJ's Avatar
It's not little! It's almost as big as the GTX285. We'll see if I can climb back into the top 10 in PPD for the team. I'm pretty happy to pull 21.5k PPD from one computer. And my OC isn't there yet. I'm very slowly sneaking it up.
Multi-GPU Problem *sigh* Soultribunal HardwareCanucks F@H Team 23 October 30, 2009 10:26 PM
Multi-GPU Folding Tips and Tricks sswilson HardwareCanucks F@H Team 13 October 26, 2009 08:02 PM
Multi GPU folding - need help Apollo4g HardwareCanucks F@H Team 4 July 17, 2009 11:13 AM
Multi-GPU PhysX implementation BrainEater Video Cards 16 May 7, 2009 03:54 PM
2 9600GT Multi-GPU PhysX ? Chromey Video Cards 1 April 1, 2009 05:04 PM
