Old November 9, 2009, 01:08 PM
martin_metal_88's Avatar
Default Setup, again?
Hey guys, Just changed my MOBO CPU MEM and when I start back my CPU console my CPU wont go any more then 44% use ( for folding ) witch is suppose to use 90% of the CPU power. I don't know if I have to re-set setting 1 by one and if there is a command line to do it or if I have to delete everything and start from bone ( I don't really want to but will if needed ) or, if it's because the F@H dos client can't get any advantage from HT witch would be plausible because it use 45% ( half of the 90% set ). look at my system spec to see what I am using I hope you guys can help me
Old November 9, 2009, 01:30 PM
well youre not supposed to use ht for folding, at least thats what pande says.
use smp if you have a dually or quad, leave ht disabled if you can..havent folded the i7's soo..someone correcxt me if im not up with the times on the said subject :p
Old November 9, 2009, 02:16 PM
HT = ON
you will need to load 4x vmware to load it at top
if you disable the ht you can do 2 vmware only
Old November 9, 2009, 02:19 PM
3.0charlie's Avatar
/\/\/\ what Phil says...
Hydro-Quebec is salivating...
Old November 9, 2009, 02:36 PM
Ah that's sad...VM wont work on my computer. The way my network is made make them impossible to connect to the internet except if I have complete VM ( not only VM player ). I will just re-do my folding setup to fix some little things and will be back folding again in few day.
What do u think about this WC setup Grosjambon Water Cooling 6 October 19, 2009 03:32 PM
[WTB] LOOKING FOR A WC SETUP _dangtx_ Buy/Sell & Trade 10 August 14, 2009 12:15 PM
[WTT] My LGA775 DDR3 setup for your AM2+/AM3 setup Realityshift Buy/Sell & Trade 2 April 12, 2009 05:17 PM
Need a setup ChuckleBrother HTPC Systems & Software 2 August 21, 2008 09:01 PM
WC setup Dark Water Cooling 24 January 14, 2008 06:02 PM
