Old November 6, 2009, 11:55 AM
odis172's Avatar
Default Prifinitty help!
Firstly, I apologize if this solution is posted elsewhere, but ive looked through several threads and was not able to find an answer.
Im trying to setup prifinitty to monitor the gpu client, and vmware. I just cant seem to find the vmware-vmx.exe executable (which is what takes up the cpu time in task manager) anywhere, to add it to prifinitty. Changing the priority of vmware (which is listed in prifinitty) does not effect the vmware-vmx.exe
Prifinitty is running as administrator, and im using vmware workstation. Thanks!
Laptop: Lenovo T420 - Core i5 2520 - 8GB DDR3
Server: 2 xeon E5530 - Asus Z8N-D6 - 12GB DDR3 - 8x 500GB raid 50 - Perc 6/i - Compucase RA448A00
Old November 6, 2009, 12:47 PM
3.0charlie's Avatar
/program files/Vmware/Vmware player/x64
Hydro-Quebec is salivating...
Old November 6, 2009, 12:51 PM
odis172's Avatar
thus proving the human brain is still superior to vista search function. thx charlie
Old November 6, 2009, 01:26 PM
odis172's Avatar
ok so i have it in the right pane now, i have auto set and enforce enabled. When i right click on vmware-vmx in the fav windows, and select the 2 cores i would like it to run on, as well as the priority and "apply." It shows in the prifinitty windows the options i have selected, though in task manager the settings are clearly not being applied. When i do this for the fahcore 11 and 14, the prifinitty settings are applied in task manager after a few seconds. Is prifinitty able to work in this capacity?
Old November 6, 2009, 03:48 PM
3.0charlie's Avatar
Ah. If you have more that one VM client, it may not be possible to set the priority and affinity using Prifinitty2. I believe there are other apps out there that can allow this. Sorry, don't know much more since I never had this issue.
Old November 6, 2009, 04:58 PM
somecanadianguy's Avatar
I had problems with Prifinitty too.
Waht OS are you running?
Try WinAFC and see if it works.
Set Affinity/Priority with WinAFC
Old November 6, 2009, 07:45 PM
odis172's Avatar
Ah I do have a few differant vms setup, ubuntu, backtrack, though they werent running at the time i was trying this. Thanks for the winafc suggestion, ill give it a shot tomorrow.
Old November 6, 2009, 08:41 PM
stoanee's Avatar
Also process lasso...
Bitsum Technologies
heatware
Old November 6, 2009, 10:42 PM
Perineum's Avatar
You can set your priority using Prifinnity for the VMs, but you have to use the VM files themselves to set the affinity.
IE: at the end of the .vmx file add:
priority.grabbed = "idle"
priority.ungrabbed = "idle"
processor2.use = "FALSE"
processor3.use = "FALSE"
Old November 7, 2009, 12:21 AM
sswilson's Avatar
Process lasso is what I'm using (more concerned with affinity than I am with priority) and it's working wonders. No searching for files at all, you just open it up with the programs running and set affinity from there.
Profanity over Prifinitty! kruzn4evr HardwareCanucks F@H Team 20 September 10, 2009 08:12 PM
