Old November 3, 2009, 07:11 PM
Polygon's Avatar
Default Is my folding working?
So I was folding before with rosetta @ home a few weeks ago, then found out the standford one is the most popular and there was the contest so I went over and downloaded that client. I've been doing some folding since yesterday but so far I'm not getting any credit and the CPU usage doesn't go to 100% or even 50% it's usually capped at around 20-40%. Furthermore there's no credit on my page and I don't appear on the HWC team.
On the little icon though I see "CPU - F@H (350/500)" and this slowly goes up in increments of 10. So it looks like things are progressing, very very slowly. I'm wondering how this gets put on my profile, and how I can make the program use more CPU usage. I also notice when I log off or let it go to screensaver it doesn't go full load either.
Thanks
'Do not wish for easier lives, wish to be stronger men'
Old November 3, 2009, 07:19 PM
3.0charlie's Avatar
You are using the STD client.
List your hardware, and we'll tell you which Client would be the most efficient for ppd.
And you can read this too: http://www.hardwarecanucks.com/forum...need-here.html
Hydro-Quebec is salivating...
Old November 3, 2009, 07:24 PM
Polygon's Avatar
Intel Q9400
8800GT 512mb
2048mb DDR2 RAM (800MHz)
Windows XP 32bit MCE
Nothing is overclocked right now, and I get decent temps.
And thanks for the link.
also, update this winter so I can maybe have two rigs going
Old November 3, 2009, 07:33 PM
3.0charlie's Avatar
Start by un-installing the client you have, and follow the GPU Client installation. Easiest of all, make sure you keep an eye on the GPU temps (may need to raise the fan speed using Precision).
Once familiar, you can install the VMware client for the CPU.
Use Fahmon (there is a sticky too) to track the WUs progress.
chrisk's Avatar
Folding Captain
You should stop using that cpu client as you won't get many points with it.
Use your video card to folding using this client:
http://www.stanford.edu/group/pandeg...ystray-623.msi
Use this guide to help you set it up:
[H]ard|Forum - View Single Post - [H]orde Guides
Once you get comfortable with that, post in here asking how to set up the vmware client to use your cpu.
Welcome to the team!
edit: I tried to ninja 3.0charlie but failed!!!
And yes...check out the sticky on setting up Fahmon too
Fold for team #54196
Old November 3, 2009, 07:59 PM
Polygon's Avatar
OK thanks for the responses, hehe GPU temps went up to 85C and are steady, with 100% fan speed :)
Currently setting up VMware and Fahmon.
Old November 3, 2009, 08:02 PM
3.0charlie's Avatar
Damn, you're quick!
Welcome to our little Addiction.
Old November 3, 2009, 08:05 PM
chrisk's Avatar
Folding Captain
Damn, you're quick!
Mikey I think he likes it!
God bless The Program.
Old November 3, 2009, 08:24 PM
3.0charlie's Avatar
make sure you have your username, and your fold for team 54196. Then enter the contest!
Old November 3, 2009, 10:15 PM
Polygon's Avatar
I have a error that comes up when trying to get the vmplayer to work... I made two folders (Q9400-1 and Q9400-2) then double clicked on the file in the Q9400-1 file... then this comes up. Anyone know why?
http://i254.photobucket.com/albums/h...C/foldprob.jpg
Absolute best Folding GPU for Folding CasheKicker HardwareCanucks F@H Team 21 February 14, 2012 10:54 AM
New and Not sure this is working. l-lunter HardwareCanucks F@H Team 14 April 21, 2009 03:41 PM
New build (almost) working SuperFriedFish Troubleshooting 6 October 21, 2008 06:16 PM
new build not working satan_2.7 Troubleshooting 2 August 17, 2008 09:26 PM
I-Trader not working? b1lk1 Suggestions & Feedback 1 September 21, 2007 06:41 AM
