<~----> Multi-GPU Problem *sigh* - Hardware Canucks
Old October 30, 2009, 06:07 PM
Soultribunal's Avatar
Default Multi-GPU Problem *sigh*
Hey guys,
Okay so I have the latest drivers ( I did the safe mode driver sweep before hand ).
Card is working , I am running XP SP3, desktop is extended.
One card is:
ASUS ENGTX260 Matrix
Second Card is:
XFX 8800GT Alpha Dog Edition
This is what I get.
01:04:06] Compiler : Microsoft (R) 32-bit C/C++ Optimizing Compiler Version 14.00.50727.762 for 80x86
[01:04:06] Build host: amoeba
[01:04:06] Board Type: Nvidia
[01:04:06] Core :
[01:04:06] Preparing to commence simulation
[01:04:06] - Looking at optimizations...
[01:04:06] - Created dyn
[01:04:06] - Files status OK
[01:04:06] - Expanded 67051 -> 348420 (decompressed 519.6 percent)
[01:04:06] Called DecompressByteArray: compressed_data_size=67051 data_size=348420, decompressed_data_size=348420 diff=0
[01:04:06] - Digital signature verified
[01:04:06]
[01:04:06] Project: 5796 (Run 19, Clone 649, Gen 6)
[01:04:06]
[01:04:06] Assembly optimizations on if available.
[01:04:06] Entering M.D.
[01:04:13] Working on Protein
[01:04:13] Run: exception thrown during GuardedRun
[01:04:13] Run: exception thrown in GuardedRun -- Gromacs cannot continue further.
[01:04:13] Going to send back what have done -- stepsTotalG=0
[01:04:13] Work fraction=0.0000 steps=0.
[01:04:17] logfile size=0 infoLength=0 edr=0 trr=23
[01:04:17] - Writing 635 bytes of core data to disk...
[01:04:17] Done: 123 -> 124 (compressed to 100.8 percent)
[01:04:17] ... Done.
[01:04:17]
[01:04:17] Folding@home Core Shutdown: UNSTABLE_MACHINE
Any Ideas?
Old October 30, 2009, 06:13 PM
BT!'s Avatar
BT! BT! is offline
i got something similar with my 9600, it said it was pausing for 24 hours due to a unstable machine bla bla bla.. i just deleted the work folder and started over. been running fine since.
Old October 30, 2009, 06:16 PM
chrisk's Avatar
Folding Captain
Do you get this on the first machine you are trying to run or the second?
Fold for team #54196
Old October 30, 2009, 06:17 PM
I've killed the work Folder a dozen times. It only happens when I try and run the 8800GT but I'll try that one more time and see.
ST
Old October 30, 2009, 06:21 PM
3.0charlie's Avatar
Add a dummy plug?
Different Client IDs?
Add the -forcegpu nvidia_g80 flag?
Old October 30, 2009, 06:23 PM
LCB001's Avatar
Folding Captain
Since you are mixing a 200 series card with the previous generation 8800GT I presume you have installed the new experimental FahCore_11 v1.31 and updated your FahCore_14 as described here New Core_14 Fixes Shader And Mixed Gen. Bugs
Folding For Team 54196
Old October 30, 2009, 06:26 PM
3.0charlie's Avatar
And: nvidia control panel/Set up multiple displays / did you check the second analog display, the one linked to the 8800GT?
Old October 30, 2009, 06:45 PM
I'll load in the new Core as well, I did delete the 14 core though
Thanks guys, were getting somewhere, at least its not crashing ATM!
Old October 30, 2009, 06:55 PM
Okay so now its just constantly cycling waiting for Work
01:53:53] + No appropriate work server was available; will try again in a bit.
[01:53:53] + Couldn't get work instructions.
[01:53:53] - Attempt #6 to get work failed, and no other work to do.
Waiting before retry.
I guess now I wait for it to grab a WU hopefully.
ST
Old October 30, 2009, 07:06 PM
LCB001's Avatar
Folding Captain
Did you reboot after replacing the core ???
Multi-GPU Folding Tips and Tricks sswilson HardwareCanucks F@H Team 13 October 26, 2009 08:02 PM
Multi-faceted problem w/ i7 rig! Woot! ImmaPC Troubleshooting 13 September 3, 2009 01:57 AM
Multi GPU folding - need help Apollo4g HardwareCanucks F@H Team 4 July 17, 2009 11:13 AM
Multi-GPU PhysX implementation BrainEater Video Cards 16 May 7, 2009 03:54 PM
2 9600GT Multi-GPU PhysX ? Chromey Video Cards 1 April 1, 2009 05:04 PM
