Old October 16, 2009, 07:40 PM
Sushi Warrior's Avatar
I re-installed it and... nothing. What exactly is the force GPU flag? -forcegpuG80?
Old October 16, 2009, 07:41 PM
werty316's Avatar
Give their standalone memory testing a run and see if it gives you any errors: Folding Forum • View topic - Announcing release: standalone memory tester for NVIDIA GPUs
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris you may be only seconds away from death.
Old October 16, 2009, 07:52 PM
3.0charlie's Avatar
Already have the forcegpu flag.
Hydro-Quebec is salivating...
Old October 16, 2009, 08:26 PM
3.0charlie's Avatar
Found out that W7 (Vista too?) has the ability to shut down monitors - not send a signal via the nvidia control panel. Only one was activated. I switched on all 4, and 5 clients are back online. The 6th one, the Core #2 of GX2 #2 is still EUE.
Old October 16, 2009, 09:00 PM
LCB001's Avatar
Folding Captain
At least you got most of them back up, I see your luck with gpu's hasn't changed.
I presume you've already tried it in a different slot...
Folding For Team 54196
Old October 16, 2009, 11:11 PM
bwm bwm is offline
Are you running XP with SP2?? If so, do you have all the net framework updates/patches installed?
I've seen net framework cause problems that no mortal would ever dream it could.
I'm clueless other than that man. You can always dunp the directory on the disk and install anew.
Just in case you have any command line switches in use, try cranking it up without them and see what happens.
Brad
Old October 17, 2009, 02:49 AM
Perineum's Avatar
3.0Charlie, try WinXP 32/64 on a spare drive!
Old October 17, 2009, 06:45 AM
3.0charlie's Avatar
Leon, I tried that single GX2 alone, same result.
Crusty, W7 here.
Perineum, I'll set XP over the week-end and check this out. Spare drive? Nah....
  #19 (permalink)
Old October 17, 2009, 07:55 AM
the man doesnt believe in spares!!!
but seriously let us know how you fixed it..i spent 1hr on the phone with brad to get the second card going a couple weeks ago
  #20 (permalink)
Old October 17, 2009, 08:03 AM
3.0charlie's Avatar
Spares? I've got too many of them. I was looking at re-installing W7 anyway.
can this work? hohohee Off Topic 16 May 27, 2009 05:50 PM
Does this work? Infiniti Water Cooling 3 January 15, 2009 07:10 PM
Will This Work? Infiniti Video Cards 2 July 21, 2008 11:54 AM
Will This Work? stormkiller22 Troubleshooting 9 March 5, 2008 06:02 PM
Will this all work? Infiniti Water Cooling 11 January 8, 2008 10:50 PM
