Old October 14, 2009, 06:07 PM
Silvgearx's Avatar
Default single VMware PPD?
so i was wondering.
my VMWare only shows 2300PPD on FAHmon, seems kinda low for a cpu clocked at 3.6ghz. I think i did something wrong
i am only running a single vmware for now.
Old October 14, 2009, 06:15 PM
sswilson's Avatar
What proc? I'm getting 2400 - 2600 on two cores of my 955be @ 3.85.
Old October 14, 2009, 06:18 PM
Silvgearx's Avatar
its a x550 x4.
does your q6600 give better PPD on VMware?
VMware is the best choice for PPD right?
Old October 14, 2009, 06:50 PM
geokilla's Avatar
Are you running the quad core VMWare Player?
I found that Folding@Home does not have a huge effect on clockspeed. My E7200 @ stock was putting out 1100PPD, which is more or less the same as my sister's AMD X2 3800+ @ 2.6Ghz. Now with it clocked at 3.73Ghz or thereabouts, I put out around 1700PPD. With VMware on my sister's AMD, I put out around 1400PPD if it's idling.
Old October 14, 2009, 07:44 PM
Perineum's Avatar
Originally Posted by 5ILVgeARX View Post
so i was wondering.
If you are running the older VMplayer and are only using 2 cores then your PPD output is exactly where I would expect.
My Q6600 on 4 cores does 4000PPD @ 3.0ghz, and that's using the newer, better (so far, anyway) VMplayer
Boost Your PPD with VMWare - Look inside for easy guides! zlojack HardwareCanucks F@H Team 416 April 7, 2010 12:19 PM
Need Help with VMware ontariotl HardwareCanucks F@H Team 28 September 26, 2009 07:20 PM
Low VMware ppd somecanadianguy HardwareCanucks F@H Team 8 September 24, 2009 02:01 PM
vmware killing my gpu PPD? BT! HardwareCanucks F@H Team 8 September 7, 2009 09:32 AM
Crazy GPU PPD, Crap CPU PPD, help please Taz HardwareCanucks F@H Team 5 July 31, 2009 05:37 PM
