Go Back   Hardware Canucks > HARDWARE CANUCKS COMMUNITY > HardwareCanucks [email protected] Team
Old October 2, 2009, 09:00 PM
Arrow guys i got two gt's in one puter
how do i get the second one going?
i hooked it up to the same monitor im using with the other one, via vga(dvi connector) and it didnt work.
whats the trick?
ill happilly fold one week for the team.
Old October 2, 2009, 09:03 PM
Sushi Warrior's Avatar
Wait, so you have two cards? Did you ever think of reading the manual?
Old October 2, 2009, 09:13 PM
i looked at the stanford thing but im doing something wrong lol
Old October 2, 2009, 09:18 PM
Oh you mean [email protected], I was looking at new posts and missed the forum
You don't need a dummy cable after 190.xx drivers. However I am a total [email protected] newb as far as settings go so I know nothing
Old October 2, 2009, 09:34 PM
What OS are you running?
Old October 2, 2009, 09:41 PM
xp 32 bit sir
Old October 2, 2009, 09:46 PM
Originally Posted by _dangtx_ View Post
xp 32 bit sir
Good, that's what I'm running and can help you.
Don't hook up a cable to the second card. Just extend your desktop onto it.
Then go here: [email protected] - WinGPUGuide
Old October 2, 2009, 09:51 PM
well i did but then got lost...when adding the fpu0 it doesnt work....my few glasses of wine dont help lol
Old October 2, 2009, 10:02 PM
The steps are essentially:
1) Go to C:\Documents and Settings\[username]\Application Data\
where [username] is your username.
Note: This folder might be hidden so you'll have to go to explorer options and unhide it.
2) Now copy the [email protected] folder and paste into the same directory. Re-name it [email protected]
3) Now go to C:\Program Files\[email protected]\[email protected].
Find the FAH executable and create a shortcut onto the desktop. Re-name it GPU1.
4) Right click on the shortcut GPU1. And click properties. Replace the Start-in path with: C:\Documents and Settings\[username]\Application Data\[email protected]
The Target path should be "C:\Program Files\[email protected]\[email protected]\[email protected]" -gpu 0
Then click OK.
5) Now make a copy of GPU1 and Re-name it GPU2.
6) Right click on the shortcut GPU2. And click properties. Replace the Start-in path with: C:\Documents and Settings\[username]\Application Data\[email protected]
The Target path should be "C:\Program Files\[email protected]\[email protected]\[email protected]" -gpu 1
Then click OK.
7) Now you can click on GPU1 to start your first GPU and then GPU2 to start the second one. Don't forget to change the machine IDs of each one to different numbers under the configure option when you right click the icons on your system tray.
Old October 2, 2009, 10:05 PM
hold on a sec. i was working with the console clients. i thought it went a bit liek with the regular cpu consoles where you just make copies, select a different id and go for it .
Sorry Guys. Spikemaul HardwareCanucks [email protected] Team 9 September 28, 2009 09:39 AM
What do you guys think.... encorp Off Topic 9 February 27, 2009 07:29 PM
Puter not booting up. Help Plz Bognostraglum Troubleshooting 19 August 13, 2008 12:06 AM
Hi Guys blogz101 Overclocking, Tweaking and Benchmarking 9 July 28, 2008 07:09 PM
Well stocked 'puter stores in Montreal? skadebo Off Topic 3 May 14, 2008 01:23 PM
