Old August 24, 2007, 03:32 PM
Amon's Avatar
Default No progress
After about a month of folding, I'm still seeing zero progress; a bit perplexing. I'm positive my user name is unique and that the machine is actually folding.
My user stats: Folding@Home
So what the hell happened? Did my computer just get some insanely complex protein?
Old August 24, 2007, 03:36 PM
sswilson's Avatar
Heh.... yeah a month of folding should have given up some points.... :)
What does your log file say... does it show any completed & submitted WUs?
Old August 24, 2007, 03:45 PM
Amon's Avatar
Hi Wilson,
I forgot to mention that halfway through, I implemented a proxy configuration under the presumption that my router was blocking the incoming work units. I guess it turns out that very same proxy setting may have blocked them altogether. I've taken it off now and will revisit this issue in a week to see if it's helped.
Old August 24, 2007, 03:54 PM
sswilson's Avatar
Originally Posted by Amon View Post
Hi Wilson,
It shouldn't take a week to know if it's managing to upload WUs.
What client are you running? You should be able to use FAHMon to monitor your progress.
Old August 24, 2007, 04:14 PM
Amon's Avatar
Folding@Home Graphical version 5.03
Old August 25, 2007, 09:47 AM
3.0charlie's Avatar
I don't get it. Graphical version is no-nonsense, barely any options. Unless your rig is unstable, it has to be your connection.
But first I would use the text-only console - much more efficient. Download Folding@Home I know, I have used both graphical and console on my P4 540J single core rig.
Also d/l Fahmon (FahMon Homepage) to keep track of your progress.
In order to setup the text-only console options, follow this guide: How do I reconfigure the console client options? - FaHWiki. Go to Configuration Options.
That's a start. Don't forget to add the Team # - 54196!
John
PS. don't forget to un-install the graphical version first.
Old August 25, 2007, 10:36 AM
Fallen Folder
also, before converting to the text console from the gui, check your fahlog.txt.
If there is a wu in progress then after stopping the gui client, copy the work directory and queue.dat file to the new directory you put the text version in. That way you will not lose any progress you have made on the current wu.
In general, always answer no to 'use IE proxy'. Very few people use proxies on the home net .... some businesses use them to control employees access to the internet.
Also, post your current log file - fah.log.txt in whatever directory you installed the gui into. Then we can see if there are any other issues.
When you set up the text console use "-verbosity 9" on the startup string so that the client will log the maximum info including info about any connection issues. If you don't know how to do it we can help.
But for now, the priority is to see your current log so we can make sure your setup is right.
When you post the log wrap it in code tags like this:
Code:
log contents
use a quote on this post to see the raw code tags.
Also, i see from your sig that you have a dual core so we will get you optimized and producing big points once we get the basics sorted out.
ps. I will probably be away till sun pm/ mon am but I am sure the others on the team can help you out ... we just need some more info from the log.
Old August 25, 2007, 11:14 AM
3.0charlie's Avatar
FYI, the FaHwiki.net link I gave in my reply shows how to add startup strings.
John
Old August 25, 2007, 11:44 AM
Fallen Folder
John
Thanks, i hadn't looked at it in a while
Old August 28, 2007, 08:02 AM
3.0charlie's Avatar
Looks like you managed to complete and upload your first WU!
Something worked.
John
In Progress: AMD X2-5000 Black (unlocked multiplier) Lithotech Member Reviews 24 May 3, 2008 08:16 PM
Progress report E6400 bushwickbill Overclocking, Tweaking and Benchmarking 5 October 12, 2007 07:19 PM
