  #61 (permalink)
Old October 21, 2009, 08:04 PM
3.0charlie's Avatar
I still haven't started the furnace in mine....
Hydro-Quebec is salivating...
  #62 (permalink)
Old October 22, 2009, 01:47 PM
fefox's Avatar
Wow I screwed up.....
so the other day after reinstalling windows xp32 (again) I noticed that windows was only reporting 1gb of ram out of the 4
so I just assumed it was because I was lazy and used the extra CD KEY off the bottom of my asus netbook (its running linux) and it was disabled to 1gb by microsoft somehow...
I then reinstall windows XP32 and use the real key and its showing 3gb... ok good, I drop in the GTX 295's and WTF its back to 1gb of ram.
so now im thinking, when I switched out the Athlon X2 5000 for the 940 X4 and upgraded the bios I tested everything under windows 7 and it was fine.
I then switched back to XP I never noticed ram difference...
So:
MSI K9A2 Platinum / Athlon X2 5000 / 1.5 bios version / XP32 works with 4xgtx 295's with 3gb total ram.
Drop in the 940, and the bios did not identify the CPU so upgraded to 1.8 bios now total Memory is 1gb in XP.
also noticed as I add or remove the 295's the total Ram changes in XP
1x295 = 3gb 2x295=2.25gb 3x295=1.5gb and 4x295=1gb
now total RAM in the bios is still 4gb and CPUID shows it still as 4 but XP can't find it all depending on the # of 295's
Windows 7 works fine...
anyone have any idea's on this?
  #63 (permalink)
Old October 22, 2009, 01:51 PM
3.0charlie's Avatar
Wasn't there an update to manage more than 2Gb in XP?
  #64 (permalink)
Old October 22, 2009, 01:54 PM
Perineum's Avatar
Isn't the amount of ram shown in Windows XP deducted from because with a 32 bit OS you need to be able to address the video card?
IE: so for every 512 meg video card you add in, you will get 512 gigs less system ram
  #65 (permalink)
Old October 22, 2009, 03:02 PM
fefox's Avatar
Well that makes sense, if its true I never noticed it before... but with 8 GPU's that would mean my windows would have Zero RAM available.
I sold my X2, so I can't go back to check but im positive it wasn't eating up the ram b4 I upgraded the bios.
Wish I had XP64 just to see if that changes anything...
  #66 (permalink)
Old October 22, 2009, 03:08 PM
sswilson's Avatar
There's a setting in bios that normally allows the "extra" memory (over and above what a 32bit OS can recognise) to be used for vid memory. Is it possible that the fact your cpu isn't recognised has affected the bios' ability to do that?
  #67 (permalink)
Old October 22, 2009, 03:11 PM
Perineum's Avatar
64 bit should solve the issue I would think....
  #68 (permalink)
Old October 22, 2009, 03:18 PM
fefox's Avatar
CPU is recognized now with the bios update.. and im sure the ram was fine b4 the bios update...
  #69 (permalink)
Old October 22, 2009, 04:21 PM
its a memory issue with 32 bit, the memory from the video cards is mapped into the 4 gig limit instead of the ram, 64 bit is the only way to solve the problem and allow you to have all the memory in the system (ram & gpu memory)
edit - forgot to add that 64 wont solve the problem if the mobo doesnt have bios support for a 64 bit os
  #70 (permalink)
Old October 23, 2009, 12:57 AM
fefox's Avatar
edit - forgot to add that 64 wont solve the problem if the mobo doesn't have bios support for a 64 bit os
I guess I just never noticed! I started using windows to fold, but everything b4 that was all 64bit stuff, Linux, Solaris, and Vista 64 for games...
machine works fine for folding, but forget doing anything else with it :)
well time to get XP64
Danger Den Brings Full Coverage to Single PCB GTX295 FiXT Press Releases & Tech News 2 July 6, 2009 01:09 PM
[WTB] EVGA GTX295 Liu Kang Buy/Sell & Trade 7 July 3, 2009 07:29 AM
Sfc not working odis172 Troubleshooting 8 June 19, 2009 11:57 PM
New and Not sure this is working. l-lunter HardwareCanucks F@H Team 14 April 21, 2009 03:41 PM
[FS] morphine's Spring cleanup - TJ07 case and GTX295 vid card morphine Buy/Sell & Trade 6 March 17, 2009 06:50 PM
