Old September 16, 2009, 09:10 AM
Lamb's Avatar
Default GPU problem?
Hey guys
I just installed the GPU client, and when I start it, my GPU starts beeping like a pig, very very annoying, is it normal...? (the higher the usage, the more beeping, over 50% it just squeel like a drill...)
BTW I'm using at GTX285 , Fahmon says ~8700pdd the gpu alone, but the squeel is terrible...can't stand it
Old September 16, 2009, 09:25 AM
3.0charlie's Avatar
Welcome to the world of squeeling folding GPUs. You'll learn to love it.
Old September 16, 2009, 09:42 AM
Lamb's Avatar
As long as my card isnt going to die...
Is there a way to make it stop?
Old September 16, 2009, 09:44 AM
Dead Things's Avatar
It's just coil whine. It is present in many GPUs and PSUs while under load. Perfectly normal operating conditions, albeit annoying to some.
Join the PPD revolution!
Proud to be Folding @ Home
deadthings @ Team 37412
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Old September 16, 2009, 09:47 AM
Lamb's Avatar
Die caps!
EDIT : Very annoying but it destroys WU's...
Old September 16, 2009, 11:58 AM
It's not the capacitors, it's the coils in the voltage regulation circuit because nVidia designed it poorly. Some ATI cards have the problem as well, but to a lesser extent.
Old September 16, 2009, 03:09 PM
chrisk's Avatar
Folding Captain
Pretty soon you won't even hear them. It's called 'Folder's Ear'...
Fold for team #54196
Dual GPU Folding on one GPU (FahCore_14 only) geokilla HardwareCanucks F@H Team 2 August 8, 2009 05:35 PM
problem with F@H on GPU Gellidius HardwareCanucks F@H Team 7 April 6, 2009 01:39 PM
Hardware problem or HAL problem? andynerd Troubleshooting 1 March 7, 2009 08:03 PM
New GPU-Z available Dwayne Video Cards 5 September 18, 2008 10:18 PM
EUE problem - G8800 GTX, 177.92 drivers and 6.2 GPU client Dwayne HardwareCanucks F@H Team 3 September 7, 2008 08:40 AM
