Old September 15, 2009, 08:32 PM
Default She's Alive...
Got my board today. Assembled the folding rig and got her running on XP Pro 32-bit. Got both G92 8800 GTSs in there.
I've installed the gpu client and tried to get my second GTS to fold but I get the error: "At present your GPU is not supported or you need a current driver. You may wish to consider running our standard client, which you can download at folding.stanford.edu."
Help on getting my second GPU to fold?
Old September 15, 2009, 08:50 PM
stoanee's Avatar
Check in here, there is lots of info....
Folding Forum • View topic - GPU not supported
heatware
Old September 15, 2009, 09:09 PM
Add the -forcegpu nvidia_g80 flag.
Old September 16, 2009, 03:21 AM
Buck Nasty's Avatar
Extend "my windows desktop onto this monitor" in display settings for GPU2. Also may sure windows loaded the drivers twice(screen flickers twice to acknowledge drivers were loaded for both GPU's).
Old September 16, 2009, 04:24 AM
3.0charlie's Avatar
Damn, the competition giving out a hand... whoa.
Don't forget you may need a dummy plug on that second GTS.
Hydro-Quebec is salivating...
Old September 16, 2009, 04:36 AM
chrisk's Avatar
Folding Captain
Don't think you need a dummy plug in XP, even with the older drivers (I never used one except Vista on he old drivers).
Make sure each GPU client has its own 'Machine ID', and try extending the desktop if possible.
I follow this excellent guide to setup dual GPUs:
[H]ard|Forum - View Single Post - [H]orde Guides
Fold for team #54196
Old September 16, 2009, 06:40 AM
I extended the desktop and now the second GPU works! Thanks guys!
It's alive!!! It's ALIVE!!! IT'S ALIIIIIIIVVVEEE!! cadaveca Off Topic 14 June 7, 2009 12:01 PM
Keep Your Brain Alive - Live Long & Prosper misterlarry Off Topic 1 May 13, 2009 09:37 PM
Microsoft may keep XP alive after all stoanee Rumor Mill 55 November 5, 2008 02:57 PM
It's alive, even after I shut down. misterd Troubleshooting 13 August 19, 2008 05:55 AM
INTERPLAY: Alive? And remaking classics? CMetaphor Rumor Mill 12 April 22, 2008 05:18 AM
