Old September 15, 2009, 12:06 PM
Default F@H Error
[18:57:43] Folding@home Core Shutdown: UNSTABLE_MACHINE
[18:57:47] CoreStatus = 7A (122)
[18:57:47] Sending work to server
[18:57:47] Project: 5766 (Run 11, Clone 330, Gen 1021)
[18:57:47] + Attempting to send results [September 15 18:57:47 UTC]
[18:57:47] + Results successfully sent
[18:57:47] Thank you for your contribution to Folding@Home.
[18:57:51] EUE limit exceeded. Pausing 24 hours.
What would cause these errors (UNSTABLE_MACHINE and EUE limit exceeded)?
Also, when I try to restart the client I get a message saying my GPU isn't supported...Any ideas?
Second Also, I'm currently connected via Remote Desktop so I can't check my card. Do you think the cards dead?
Current Rig: C2D E6400 @ 3.0GHz, Vendetta II, BFG 8800 GT, OCZ PC6400 8GB, HX520W, 2x WD 500GB HD, Segate 160GB, WD 200 GB HD, Lancool PC-K62, Windows 7 64 bit, Snow Leopard (on the way)
EVGA 680i SLI Motherboard $80 + Qualitas 73GB 10k SCSI $30
Old September 15, 2009, 01:56 PM
3.0charlie's Avatar
No. Either your oc is too high (shaders), or it's a bad WU. You need to delete the Work folder and the Queue file, and restart the client.
Old September 15, 2009, 02:39 PM
Yup, everything works now. Was a little worried because I hadn't encountered that and I couldn't check on my card :P
never before seen error message newagebiker O/S's, Drivers & General Software 2 July 8, 2009 10:56 PM
Mystery error . . . NyteOwl Troubleshooting 4 September 6, 2008 06:59 PM
Opera error Kilauea Suggestions & Feedback 6 September 5, 2008 05:59 PM
BSOD error miggs78 Troubleshooting 9 August 20, 2008 03:22 PM
fatal error help maurier CPU's and Motherboards 1 June 13, 2008 07:10 PM
