Old September 14, 2009, 10:22 AM
Default Rosetta Question
On my wife's e6850 rig, Rosetta tasks are now taking nearly twice as long as before. This normal ?
Old September 14, 2009, 02:40 PM
Could it be because I changed the "additional work buffer" from 0.25 to 3 ? At that point it gave me 25+ tasks and it seems like that's when it starting taking twice the time to finish the tasks.
Old September 14, 2009, 03:28 PM
3.0charlie's Avatar
The additionnal work buffer is strictly related to the number of WUs in your backlog.
Are you folding using the GPUs on that rig? You may need to adjust the Priority.
Hydro-Quebec is salivating...
Old September 14, 2009, 06:35 PM
Yes. Should I put the "Priority" higher for Rosetta tasks ? What do you suggest ?
Old September 14, 2009, 07:13 PM
Silvgearx's Avatar
of course rosetta is alway set to low
Old September 14, 2009, 08:19 PM
Chilly's Avatar
Rosetta's WU's used to have a default "work time" of 3 hours, recently this was changed to 6 hours. Its not uncommon to see your work time double, but don't fret you should still be getting around the same amount of points.
Another possible thing is that your GPU folding may be effecting the amount of CPU power available to Rosetta. Hope that helped
Old September 14, 2009, 09:09 PM
Task that takes 6hrs should get same amount pts as 2x tasks that take 6hrs in total ?
Old September 14, 2009, 10:49 PM
Chilly's Avatar
Correct, this is assuming that its the "3 hours" vs "6 hours" default WU time affecting your system(which if you never customized the settings, is most likely the case).
Rosetta/Poem Gellidius HardwareCanucks F@H Team 0 August 6, 2009 07:10 AM
question for you rosetta guru's Phobia HardwareCanucks F@H Team 12 February 21, 2009 08:30 AM
Different clients for Rosetta? biff HardwareCanucks F@H Team 1 December 10, 2008 11:03 AM
Question on BOINC - Rosetta at home matsta31 HardwareCanucks F@H Team 1 September 5, 2008 05:53 PM
F@H vs rosetta@H? elninio HardwareCanucks F@H Team 1 February 4, 2008 09:44 PM
