Old September 11, 2009, 03:36 PM
kruzn4evr's Avatar
Default What to do when this happens....
I'm not sure if I should do anything or just let it go and see if it corrects itself but the work could not be sent to HTTP, it seems to still be folding but will it not hold up the work eventually?....it's retried a few times over the last hour or so.
Any advice would be appreciated.....and I was having such a good day too!
Old September 11, 2009, 03:39 PM
Dead Things's Avatar
503 is a busy server. It will keep trying to send until it finally does go through. Nothing to worry about. Happens all the time.
Think you can overclock? Then show us what you got!
Join the Hardware Canucks Overclocking team today!
Follow my benching, folding, mining and miscellaneous shenanigans @dt_oc
Old September 11, 2009, 03:40 PM
El_Fiendo's Avatar
It keeps it saved until its sent off. I find if I hit Ctrl + C to close the client, then open it back up it usually transfers. So you know, if you leave it, it will continue to retry until it actually sends.
Old September 11, 2009, 03:49 PM
kruzn4evr's Avatar
Ahhhh...ok, will it hold up sending the current ones when they finish because the previous hasn't been sent yet?....thanks for the fast answers guys
Old September 11, 2009, 04:09 PM
It will try to send any units when you complete them, and if it can't send them it will save them in the queue. You can have multiple units in the queue, so no matter what, they'll get sent eventually.
Old September 11, 2009, 04:15 PM
kruzn4evr's Avatar
Good to know, thx Zero, I'll just keep folding away then
