Notice on my dual SLI setup there are 2 copies of both 14 and 11, just like 3.0Charlie said....
I also find that if you limit affinity on your GPU clients it eats into your PPD. The way I have it set up now the GPU client can hop to whatever core is available to feed it work.
Also, notice the "airplane" and "shield" icon are selected on. The plane is "auto set favorites", that is, the list on the right. The shield is set to re-enforce the affinity/priority once a minute, in case anything changes.
