Old September 10, 2009, 01:26 PM
kruzn4evr's Avatar
sorry, back on topic....I have to go out for a bit but I'll mess around with it again when I get back, I'm sure I'll have more questions because I just don't seem to be getting it...using prifinitty that is!...lol
Old September 10, 2009, 01:49 PM
stoanee's Avatar
Win7x64 does not play all that nice with Prifinnity, I haven't found a suitable replacement either.
heatware
Old September 10, 2009, 01:54 PM
Perineum's Avatar
hmmmmm. I'll peek around myself...
Old September 10, 2009, 04:56 PM
El_Fiendo's Avatar
Hmm, ok I wasn't sure if I was nutter or not, but yes my Win7 x64 has been what I'm having trouble on. I was pretty sure it worked with Vista x64, I just no longer have it to test with. I assumed it was a program error (not OS) because not much is different between Vista x64 and 7 x64.
Anyways, I'm always looking for upgrades. Stoanee, if you see anything I'd appreciate if you could post it up. I'll do the same.
Old September 10, 2009, 05:00 PM
Perineum's Avatar
I'm running Vista 64x and it's totally fine here
Old September 10, 2009, 05:01 PM
El_Fiendo's Avatar
Win 7 x64 (possibly x32) compatibility issue then. Wonder what changed to make things not play well together? And this will change my plans for Win7 if I can't run my VMs without issue in it.
Old September 10, 2009, 05:07 PM
kruzn4evr's Avatar
Ok well, it seems to be playing nice at the moment, I deleted the fav list I had and added them back in and clicking the auto set and shield buttons and it seems to be working. I still can't change the cpu affinity though, the 3 cores are still just showing 1 cpu core in use each, everything else shows 01234567...not sure if I can or if I want to change it because the PPD is looking pretty good at around 27K with 1 vm client. I'll keep an eye on it and see if it continues to work ok.
Thanks for the help guys, I'll be back with more questions I'm sure
Old September 10, 2009, 05:27 PM
Perineum's Avatar
Well, I've installed and am trying to use
Download Bill2's Process Manager 3.3.1.2 - This software will help you manage, rule, and then will memorize the priority and the affinity of the processes carried out. - Softpedia
It's listed as supporting WinXP / Vista / W7
  #19 (permalink)
Old September 10, 2009, 05:32 PM
kruzn4evr's Avatar
Cool!...let me know how you make out with it and I'll have a look at it too, thanks Perineum
  #20 (permalink)
El_Fiendo's Avatar
Me too! Thanks man.
