Old September 9, 2009, 03:29 PM
geokilla's Avatar
The heat of the GTX295 will kill something unless you got really great cooling.
As for the best folding setup if cost wasn't an issue....You'd have to ask the others lol. Is this for the ongoing Folding contest?
Old September 9, 2009, 03:36 PM
Sushi Warrior's Avatar
Well if money was no object they'd be on LN2. Or at least watercooled into the realms of insanity, lots of rads with maybe some peltiers or something.
Old September 9, 2009, 03:39 PM
geokilla's Avatar
Don't you have to refill the LN2 every so often because the nitrogen would evaporate as the CPU and other components heat the nitrogen up? From my chemistry knowledge and google, nitrogen doesn't become a liquid till it's like -196C?
Old September 9, 2009, 03:50 PM
bissa's Avatar
relatively stock as in water cooling and some OCing might be an option but nothing like liquid nitrogen.
also this is because of the contest, it got me interested and wanting to do more once I have a larger spending budget (in a couple years). I want to know where the "sky" generally is for the sky is the limit.
also I am aware that planning a build now would be useless, but it is fun and useful to learn things.
Strong like hummingbird, swift like oak.
I'm sorry july, I couldn't see you behind all that feruary.
Old September 9, 2009, 04:27 PM
If money is no option you would have enough LN2 to fill a lake. You'd have a truck outside your house always. ANd you'd be able to hire someone to pour it. This is the ULTIMATE machine, not most practical.
Old September 9, 2009, 04:29 PM
Originally Posted by bissa View Post
EDIT: what does affect how well a GPU can fold?
Number of shaders, shader speed, and overall GPU architecture.
The new Classified 4x SLI mobo with 7 GTX295's with waterblocks and single slot brackets? Or does the mobo not support that many GPU's? Rather have 7 295's over another processor.
There is a limit to how many GPUs you can use in a system altogether. See below for more info.
Originally Posted by El_Fiendo View Post
I think there is a limit of 4 GPUs. I'm not sure if this is Windows or Forceware drivers (or even a hardware issue). It's not an SLI issue (as in SLI will work up to x4 but you can have more graphics cards un-SLI'd), I think more along the lines of actual GPU recognition past 4 of them. I'm probably wrong though. Anyways, I've never seen anyone run 4 GTX 295s without at least 1 core giving them an issue, so I'd personally stick to GTX 285s.
Based on experiments from other users with regards to large multi-GPU setups, this seems to be the conclusion: there is a fundamental limit in Windows that permits only up to eight display outputs. That means that you can use no more than four dual-GPU cards in one system, and even four single-GPU cards would use up that number. Furthermore, Windows Vista sees cards like the GTX295 and 9800GX2 as having three outputs per card due to the separate HDMI port in addition to the two DVI outputs, so that ends up limiting Vista machines to 5 GPUs (the first two dual-GPU cards count as 6 outputs, and one of the GPUs of the third dual-GPU card counts as two outputs). XP doesn't have that problem, so you can fold on up to 8 GPUs under that OS. However, you can't use any more than that.
Old September 9, 2009, 04:56 PM
Why not just build a massive server rack with LOTS of dual CPU, 2-3 295's? If you say the cost is limitless then the specs can go to infinity...
Old September 9, 2009, 04:57 PM
3.0charlie's Avatar
Google Atlas Folder.
Hydro-Quebec is salivating...
  #19 (permalink)
Old September 9, 2009, 05:15 PM
To save everyone the trouble: Atlas’ Specs | Atlas Folding
Every PPD mean upgrade? martin_metal_88 HardwareCanucks F@H Team 11 September 3, 2009 05:58 AM
Crazy GPU PPD, Crap CPU PPD, help please Taz HardwareCanucks F@H Team 5 July 31, 2009 05:37 PM
PPD down a little... any ideas? somecanadianguy HardwareCanucks F@H Team 9 July 30, 2009 01:04 PM
Shader vs ppd phil3_66666 HardwareCanucks F@H Team 6 May 21, 2009 08:06 AM
where'd all my PPD go? Gamashinoch HardwareCanucks F@H Team 15 September 5, 2007 04:03 PM
