Old September 6, 2009, 06:46 AM
Arinoth's Avatar
Default VMWare Client Folding Errors
My CPUs wont fold now, i keep getting this error that is shown in Fahmon. Anyone have an idea how i can fix this? It keeps saying 4 cores are required or something even though the client is set to request work orders just for 2 cores at a time.
Old September 6, 2009, 07:45 AM
stoanee's Avatar
Did you change anything? Were they folding properly before?
heatware
Old September 6, 2009, 07:56 AM
3.0charlie's Avatar
I found the same error on client #6 this morning. I had to delete the VM and re-install it. Not your fault, looks like a bad WU.
Old September 6, 2009, 08:09 AM
Arinoth's Avatar
It appears updating to the latest version of VMware has fixed my problem of those bad WUs (without having to have to delete the folder and reconfigure everything).
PDD seems lower then normal on cores and on gpu for some reason...
Thank you kindly John
Old September 6, 2009, 09:27 AM
Jake_HT's Avatar
Instead of making another thread... how does a person (such as myself) make it so the vmware player will get SMP WU's... instead of these crappy regular ones? I see you did it arinoth.. how? lol..
http://jakeht.deviantart.com/
Old September 6, 2009, 09:32 AM
chrisk's Avatar
Folding Captain
Can you show me the path to one of those two folding clients?
Fold for team #54196
Old September 6, 2009, 09:36 AM
Jake_HT's Avatar
This?
\\192.168.2.16\c\etc\folding\1\
Old September 6, 2009, 09:45 AM
chrisk's Avatar
Folding Captain
OK I was wondering if you were pointing to a regular smp client (not vmware but something else).
Access your vmware client by typing in : 192.168.2.16 in internet explorer.
Check the following that I have italicized:
Found 2 processors
User: chriskwarren
Team: 54196
Passkey:
Big Packets: big
Advmethods: yes
Check to make sure advmethods says yes, and that big packets are set to big.
Also,if you change the advmethods and big packets, remember that if you change this, you will still need to finish your downloaded core/work, before the new stuff is downloaded. You will not see anything change in FahMon for some time. You can let the work finish, or delete the folding folder and set it up again (there are other ways to reset it, but for simplicity sake right now this is what I suggest)
Old September 6, 2009, 10:01 AM
Jake_HT's Avatar
Thanks Chris, it's all set like that already.. i guess I'll just wait till this crappy WU finishes to see if I pickup an SMP WU. If not, I'm going to burn some things!!!!!
Old September 6, 2009, 12:34 PM
Arinoth's Avatar
I dont know why my CPU and GPU pdd are lower then they should be. Typically if its one core its 3200 estimated PDD and with a 787 its normally somewhere in the 8k PPD. Has something magically gone on that's lowered my pdd from somehow moving from one location (home) to another (residence)
Folding under VMWare help headsh0t HardwareCanucks F@H Team 8 August 18, 2009 10:44 PM
VMWare client stuck Arinoth HardwareCanucks F@H Team 0 August 2, 2009 05:53 PM
Folding with SMP Client - Nodda Happening CasheKicker HardwareCanucks F@H Team 43 February 28, 2009 07:29 AM
Folding using the Nvidia Client? Heres some Tips Dashock HardwareCanucks F@H Team 90 September 14, 2008 06:28 PM
Linux SMP folding using XP / Vista + VMware sswilson HardwareCanucks F@H Team 100 May 12, 2008 07:28 PM
