<~----> Low PPD on VMs - Hardware Canucks
Old August 30, 2009, 10:42 AM
Perineum's Avatar
Default Low PPD on VMs
Some of you may notice that your VMs are not using 100% processor time and where one VM would get ~2500PPD nomally is now getting ~400PPD
On my Q6600 cores 0/1 are at 100% use and are ~2500PPD. However, cores 2/3 are sitting anywhere from 10 to about 30% cpu usage and get miserable speeds.
It *seems* to be bad 1920 WU's
F47-VM1, p2677 (19-51-34)
F41-VM2, p2677 (33-42-31)
F32-Linux1, p2669 (12-50-160)
F45-VM1, p2669 (14-166-39)
F38-VM1, p2677 (17-74-29)
F43-VM1, p2677 (19-51-34)
F41-VM1, p2677 (34-40-30)
F30-Linux1, p2671 (37-79-78)
My problem ones are all from Project 2677
Solution seems to be to delete the WU and get a different one.
Now.... how to make this EASY to do?
Old August 30, 2009, 10:53 AM
chrisk's Avatar
Folding Captain
Yup if anybody else sees this its bad WUs:
Folding Forum &bull; View topic - List of SMP WUs with the "1 core usage" issue
Delete the vmware 'folding.zip' created folder, or just let the WU pass and get done. No problem on your end.
Fold for team #54196
Old August 30, 2009, 10:57 AM
Perineum's Avatar
They fold so slow I can't actually complete it by the deadline.
Old August 30, 2009, 10:59 AM
stoanee's Avatar
I right click on the client in FAHmon, click on view client files and delete the work folder. Folding then downloads a new WU.
heatware
Old August 30, 2009, 11:26 AM
SugarJ's Avatar
GENIUS! I've been deleting my VM and reconfiguring. THANK YOU!
Old August 30, 2009, 11:31 AM
stoanee's Avatar
No probs, glad I could help.
heatware
Old August 30, 2009, 11:40 AM
chrisk's Avatar
Folding Captain
Yeah I did not know this either. I'll make a note of it and add it to my FaHMon tutorial!!
Perineum's Avatar
You know, I ASSumed that wouldn't work because the files would be in use. I was trying to do it by logging into the VM and killing off the processes by PID, etc.
Old August 30, 2009, 12:02 PM
Arinoth's Avatar
So have i dammit, well now i know, and knowing is half the battle!
Old August 30, 2009, 12:28 PM
somecanadianguy's Avatar
Oh... and I didn't know that either.
Thanks stoanee!
That's info that would be good in the VMware setup sticky thread.
Crazy GPU PPD, Crap CPU PPD, help please Taz HardwareCanucks F@H Team 5 July 31, 2009 05:37 PM
Shader vs ppd phil3_66666 HardwareCanucks F@H Team 6 May 21, 2009 08:06 AM
What kind of PPD should I be getting? Daygard HardwareCanucks F@H Team 2 April 29, 2009 07:06 PM
Scythe Shuriken Low Low-Profile CPU Cooler Hardware Canucks Air Cooling 0 April 30, 2008 09:24 AM
where'd all my PPD go? Gamashinoch HardwareCanucks F@H Team 15 September 5, 2007 04:03 PM
