  #41 (permalink)
Old September 6, 2009, 12:01 PM
If they aren't there, add them:
Code:
priority.grabbed = "idle"
priority.ungrabbed = "idle"
  #42 (permalink)
Old September 6, 2009, 12:57 PM
chrisk's Avatar
Folding Captain
Code:
Doesn't seem to be working. I added the two lines and my GPU ppd has dropped like a stone. (from 9000PPD to 6000PPD each. GPU temps are about 20c lower as well). Here is a look at my vmx config:
#!/usr/bin/vmplayer
.encoding = "windows-1252"
# This is a Workstation 5 or 5.5 config file
# It can be used with Player
config.version = "8"
virtualHW.version = "4"
# Number of virtual CPUs. Your virtual machine will not
# work if this number is higher than the number of your physical CPUs
numvcpus = "2"
# Memory
memsize = "1152"
# Selected operating system for your virtual machine
guestOS = "other-64"
# displayName is your own name for the virtual machine
displayName = "folding1"
# These fields are free text description fields
annotation = "Diskless Folding@Home"
guestinfo.vmware.product.long = "Diskless Folding by Nick Reilly"
guestinfo.vmware.product.url = "http://reilly.homeip.net"
guestinfo.vmware.product.class = "virtual machine"
# First serial port, physical COM1 is not available
serial0.present = "FALSE"
# Optional second serial port, physical COM2 is not available
serial1.present = "FALSE"
# First parallel port, physical LPT1 is not available
parallel0.present = "FALSE"
# Settings for physical floppy drive
floppy0.present = "FALSE"
# Logging
logging = "FALSE"
# These settings decides interaction between your
# computer and the virtual machine
isolation.tools.hgfs.disable = "FALSE"
isolation.tools.dnd.disable = "FALSE"
isolation.tools.copy.enable = "FALSE"
isolation.tools.paste.enabled = "FALSE"
# First network interface card
ethernet0.present = "TRUE"
ethernet0.virtualDev = "e1000"
ethernet0.connectionType = "bridged"
ethernet0.addressType = "generated"
ethernet0.generatedAddressOffset = "0"
ide0:0.present = "TRUE"
ide0:0.fileName = "folding1.vmdk"
ide0:0.redo = ""
extendedConfigFile = "folding1.vmxf"
virtualHW.productCompatibility = "hosted"
tools.upgrade.policy = "manual"
ethernet0.generatedAddress = "00:0c:29:e8:3f:08"
uuid.location = "56 4d fc 55 89 06 9c 22-17 fd 1f 36 2b e8 3f 08"
uuid.bios = "56 4d fc 55 89 06 9c 22-17 fd 1f 36 2b e8 3f 08"
vmotion.checkpointFBSize = "16777216"
debugStub.linuxOffsets = "0x0,0xffffffff,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x 0,0x0,0x0,0x0"
Did I enter the two lines wrong? If so you might have to be more specific, as this is my only real experience working with virtual machines.
Fold for team #54196
  #43 (permalink)
Old September 6, 2009, 01:19 PM
I copied the lines directly from my own configuration. Everything looks fine to me, but if you like you can take a look at mine:
Code:
#!/usr/bin/vmplayer
numvcpus = "2"
# Memory
memsize = "1024"
displayName = "notfred's 1"
# Logging
logging = "FALSE"
ide0:0.fileName = "folding.vmdk"
ide0:0.redo = ""
extendedConfigFile = "folding.vmxf"
ethernet0.generatedAddress = "00:0c:29:04:a6:aa"
uuid.location = "56 4d f8 d1 fc 47 6b f6-1d fa 58 53 85 04 a6 aa"
uuid.bios = "56 4d f8 d1 fc 47 6b f6-1d fa 58 53 85 04 a6 aa"
vmotion.checkpointFBSize = "22675456"
checkpoint.vmState = ""
ethernet0.features = "1"
ethernet0.networkName = ""
tools.syncTime = "FALSE"
debugStub.linuxOffsets = "0x0,0xffffffff,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0"
  #44 (permalink)
Old September 6, 2009, 01:27 PM
chrisk's Avatar
Folding Captain
Thanks zero. I'm going to let all of them run for a while and see if the PPD picks up. Perhaps the vmware took some cpu time before I had a chance to change them.
Getting the priorities straight without a program would be excellent so I will not give up on it if its possible. If my PPD does not get to normal I'll take a really close look at your settings. Thanks!
edit: no they are down to ~5000PPD now. I'll have to look again...
  #45 (permalink)
Old September 6, 2009, 01:32 PM
Take a look in Task Manager and see if the instances of vmware-vmx.exe are actually being set to low priority. If they are, check the priority on the fahcore_11.exe and fahcore_14.exe processes and see if they're higher. You'll still need something to raise the priority of the GPU clients even if you don't need to use it for the VMs.
  #46 (permalink)
Old September 6, 2009, 01:56 PM
chrisk's Avatar
Folding Captain
That would require Prifinnity again, which also works for the vmware clients.
Looking at task manager shows the GPU cores running at low, which is normal as far as I know. This occurs even if you have 'slightly higher' selected in the Advanced properties.
Are you running the GPU clients alongside the vmware clients?
  #47 (permalink)
Old September 6, 2009, 02:06 PM
I'm running an ATI GPU client alongside my two VMs, using Bill2's Process Manager to raise the GPU client to High. Setting the priority lines for the VMs works for setting mine to low priority. Anyway, if you can't get it to work, using Prifinity to set the priority will be fine. You should use it to elevate your GPU clients anyway.
  #48 (permalink)
Old September 6, 2009, 07:54 PM
Perineum's Avatar
Here is the end of my file:
processor2.use = "FALSE"
processor3.use = "FALSE"
This is for the VM that runs on cores 0+1
  #49 (permalink)
Old October 25, 2009, 11:41 AM
3.0charlie's Avatar
Time to revive an old thread.
W7.
Dual GX2s.
nvidia drivers 191.07
Crossfire board, K9A2 Platinum in my case.
Screen properties, Extend desktop must be enabled.
nvidia Properties, Physx enabled, no dot select multi-gpu setup.
And the kicker: there must be a plug in all DVI connectors.
With that setup, 4 GPU clients are up and folding. Took me a week to find out what the [bleep] was happening...
Hydro-Quebec is salivating...
  #50 (permalink)
Old October 25, 2009, 07:40 PM
chrisk's Avatar
Folding Captain
How many did you get running without any dongles?
How to set up HFM.NET and FahMon to monitor Folding@home progress. Now with videos. chrisk HardwareCanucks F@H Team 132 November 2, 2012 06:07 PM
Resistors for VGA Dummy Plug Prof. Dr. Silver HardwareCanucks F@H Team 25 August 24, 2011 05:04 AM
Dummy plug? martin_metal_88 Video Cards 11 July 6, 2009 11:47 AM
Can someone help me set up folding on my SLI? zlojack HardwareCanucks F@H Team 27 February 16, 2009 05:25 AM
New Nvidia Drivers / SLI Multi Monitor + SLI on X58 - 180.48 probationer O/S's, Drivers & General Software 14 November 26, 2008 09:40 AM
