  #21 (permalink)
Old September 6, 2009, 08:47 AM
chrisk's Avatar
Folding Captain
If you are using Prifinity take a look at the names of the processes running again. Look for any F@H cores and add them again (ie. if you have FahCore_11 in your favourites, check to see if you can add FahCore_11 again). I believe the reason is that each GPU folder has its own core, and each needs to be added. Set each one to 'High'.
Over time, I always end up with FahCore_11 and FahCore_14 being added to my Prifinity favourites list twice (for the gpu1 and gpu2 folders).
Fold for team #54196
  #22 (permalink)
Old September 6, 2009, 08:50 AM
stoanee's Avatar
Roger that, I have them set in prifinnity twice but at "normal" with the vms to "low". I will change to high and monitor.
heatware
  #23 (permalink)
chrisk's Avatar
Folding Captain
I'll upload a screenshot in a sec
  #24 (permalink)
Old September 6, 2009, 08:52 AM
chrisk's Avatar
Folding Captain
Here is a screenshot of what I have that seems to work:
  #25 (permalink)
Arinoth's Avatar
Should FahCore_11 or FahCore_14 be set to high, and what do you normally set your Folding@Home priority to Chris?
Here I am: here I remain
  #26 (permalink)
Old September 6, 2009, 08:56 AM
chrisk's Avatar
Folding Captain
There should be a screenshot of this above your post now
  #27 (permalink)
Jake_HT's Avatar
HOW DID YOU GET VMWARE-VMX PROCESS TO SHOW UP IN PRIFNITTY!!!!!!!!!!! This is making me go NUTS!!!!!!!!
http://jakeht.deviantart.com/
  #28 (permalink)
Old September 6, 2009, 08:59 AM
chrisk's Avatar
Folding Captain
That was XP BTW.
Make sure you can see all you processes. You can also add the process Manually by clicking the 'Browse for Favourite' folder icon at the top. Then you navigate to the vmware-vmx.exe folder yourself, even if you don't see it in Prifinity normally.
  #29 (permalink)
Old September 6, 2009, 09:03 AM
Jake_HT's Avatar
Originally Posted by chriskwarren View Post
That was XP BTW.
Where's the button for that?
Okay I added in the vmware-vmx process to my favs, however, it is not showing on the left side... since it's only showing 31 of 76 processes.. the show all button for some reason cannot be found by me lol
  #30 (permalink)
Old September 6, 2009, 09:05 AM
stoanee's Avatar
I see you have your affinity set to one or the other core. In my systray config I have checked "do not lock core to specific cpu" and in prifinnity I have the gpu's set to "all cores"
On another note, how do I magnify my pic? I have noticed it is a little small.
heatware
How to set up HFM.NET and FahMon to monitor Folding@home progress. Now with videos. chrisk HardwareCanucks F@H Team 132 November 2, 2012 06:07 PM
Resistors for VGA Dummy Plug Prof. Dr. Silver HardwareCanucks F@H Team 25 August 24, 2011 05:04 AM
Dummy plug? martin_metal_88 Video Cards 11 July 6, 2009 11:47 AM
Can someone help me set up folding on my SLI? zlojack HardwareCanucks F@H Team 27 February 16, 2009 05:25 AM
New Nvidia Drivers / SLI Multi Monitor + SLI on X58 - 180.48 probationer O/S's, Drivers & General Software 14 November 26, 2008 09:40 AM
