Old August 8, 2009, 01:12 PM
somecanadianguy's Avatar
Default gtx275 hit 10k+ ppd...?
Noticed shortly after starting the GPU client f@hmon was showing over 10Kppd.
Not sure why it was that high... usually it's around 8.5 - 9k on the 472pt WUs.
Old August 8, 2009, 01:24 PM
Arinoth's Avatar
What do you have your priories a (in Prifinity)t, i don't seem to get that high in pdd compared to you and we're both at 3.8Ghz
Old August 8, 2009, 02:05 PM
geokilla's Avatar
You probably had the 353 point WU.
Old August 8, 2009, 02:07 PM
Spikemaul's Avatar
Hey Canadianguy. I've been watching your folding progress since you passed me . I have only one GTX 275SC though with the shaders set at 1580 and usually get only 8k ppd on the 472 WU's. What do you have your shader's set at? This is the first reply from my new iPod Touch . Happy Folding
Edit: I now see you only have the one 275.
Old August 8, 2009, 11:36 PM
Spikemaul, shaders are @ 1666... core 666; mem 1199.
I wish I had another 275 folding away, but for now it's just the one.
geokilla, It was a 472pt WU, which I usually get around 8800ppd.
I'm not really sure why it was so high that time.
Arinoth, I've got VMware priority set to 'normal', and GPU set to 'above normal'.
I was only running 3 clients at the time I took that screenshot.
With 4 running I usually get 2400 - 2500ppd per client.
Old August 9, 2009, 08:41 AM
geokilla's Avatar
In that case, 472 point WU and 1888 point WU don't have an exact PPD that can be calculated by FahMon and such programs because their folding speed varies. There was talk about this when these WU were released. The threads can be found at the Folding Forum, though I personally don't know where it was. I just recall reading it.
Old August 9, 2009, 08:42 AM
Arinoth's Avatar
Ah ok somecanadianguy, i seem to average/float around 2.3-2.4k (with 4 instances) depending on what i'm doing on the computer at the time and i have the same priorities as you
4890 vs GTX275 (VALUE) wonton1017 Video Cards 20 August 1, 2009 10:05 AM
Crazy GPU PPD, Crap CPU PPD, help please Taz HardwareCanucks F@H Team 5 July 31, 2009 05:37 PM
Overclocking a GTX275... somecanadianguy Overclocking, Tweaking and Benchmarking 7 June 15, 2009 09:49 PM
GTX275 Installation? somecanadianguy Video Cards 4 May 29, 2009 12:13 AM
