Old August 4, 2009, 11:36 AM
Arinoth's Avatar
Lol a little harder for me to see a drop or not, i'm trying to get my g/f to set up the fahmon monitor on her computer so i can at least see if something is up but i wont be able to monitor it directly myself unless someone has made an app or knows a way to do it. I could try the vpn but what is the name of that damn app most people use for it (gaming and sorts) and if it would still be able to monitor it and not get confused (all i want to monitor is a vmware client so an ip address!)
Old August 5, 2009, 10:21 PM
Thanks for the tips I can use this for when i start folding again
Old August 10, 2009, 06:16 PM
Perineum's Avatar
Could this be it?!
fahweb.com
Old August 10, 2009, 07:49 PM
bissa's Avatar
You could set up port forwarding to the computer to be monitored from the router it is connected to. Then find out that routers public IP and type from the computer you are monitering from you run MSTSC and type in IP:portnumber so if the IP is 1.1.1.1 and the port you set it up for is 10000 then you would put in 1.1.1.1:10000and you can use the remote desktop to visually moniter it.
Strong like hummingbird, swift like oak.
Lan Monitoring Software CORE Networking 7 February 29, 2012 05:22 AM
Monitoring Multiple Video Cards Soultribunal HardwareCanucks F@H Team 10 May 27, 2009 07:21 PM
Hardware Monitoring - What's correct. Malam Air Cooling 7 December 21, 2008 08:53 AM
PC Monitoring chibi_man O/S's, Drivers & General Software 5 November 25, 2007 10:46 AM
Voltage and PSU monitoring software BALISTX Power Supplies 10 September 5, 2007 05:05 PM
