Old July 23, 2009, 09:00 AM
badatcards's Avatar
Default not bad temps with 511's
Its 20*c and raining outside right now but my room it not to hot even though I keep getting those (I got my PS3 folding to). So any of you that are not folding because of the heat and those .its not that bad, I could even crank up the fan to lower it more but i like to have the fan set to what ever the temp is.Its going to be around 20*c and raining all week.It might be a good week to start folding again.
Old July 23, 2009, 11:33 AM
Are you only using the regular CPU client? You could use VMWare and get like 10x more points with the CPU :)
Old July 23, 2009, 10:46 PM
somecanadianguy's Avatar
My gtx275 is working on a 511 right now...
GPU temp is 78c - 80c.
Room temp is around 25c...
511s
Summer
Old July 24, 2009, 09:59 AM
You can probably lower your temp even more by underclocking the core & memory, and then OC the shaders since this has the greatest effect on your PPD.
Old July 24, 2009, 10:10 AM
I only have the shaders OCd right now.
Well, core and mem were factory OCd...
Running @ 648/1644/1188 with fan @ 80%.
Part of my problem is case airflow.
511? badatcards HardwareCanucks F@H Team 11 June 25, 2009 07:25 PM
Very bad situation! mailaw Troubleshooting 32 April 28, 2009 05:23 PM
511 WUs Dwayne HardwareCanucks F@H Team 24 April 28, 2009 04:52 AM
DC - All that bad? JD Off Topic 16 December 24, 2008 07:27 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
