Old July 21, 2009, 08:07 AM
Gellidius's Avatar
Default slow folding with GTX 280
right now my gpu is working on Project 5912 (R13, C54, G3);
Credit:1888 points,
and Fahmon says my PPD are a lowly 2450.
Logically (or mathematically), it means my gpu should take about 18 hours to do the job!
Is that normal for this project?
Jacques
Ego cogito, ergo deus non est.
Old July 21, 2009, 08:51 AM
Gellidius's Avatar
well, i guess it could be this particular 5912 project that's very slow, because i just started folding a Project 5765 (353 points), and the PPD is over 7000.
Anyone can tell for sure?
Jacques
Old July 21, 2009, 09:20 AM
Prof. Dr. Silver's Avatar
No you can't tell for sure... I've noticed a slight drop in PPD as well. Normally I do around 16-17K PPD and now I'm only at 15K. I run the same clients 24/7 and did not change anything in my config...
It's a little frustrating isn't it? As for the 1888's, they take a longer time, but they're better for your hardware... less strain = lower temps :)
Hardcore Folding at it's BEST! HWC - TPU.... There can be only one team in front! TPU, can you smell our *sses already?
Old July 21, 2009, 09:28 AM
geokilla's Avatar
2450PPD for your GTX280 folding a 1888 point WU is not right. Check your clock speeds to make sure that they aren't in 2D mode.
Old July 21, 2009, 09:35 AM
3.0charlie's Avatar
It can happen. I've had a few WUs (511s, 1888s, 472s) that took longer than others. Bugged WU? Possibly, though they always folded properly and the next one in line had proper ppd. Temps / clocks / render mode (3D) were fine.
I would not worry, as long as the temps are fine.
Old July 21, 2009, 11:14 AM
Gellidius's Avatar
thanks guys; everything is running fine, temps, clocks and 3D mode;
only that particular WU was so slow. It was successfully uploaded but i don't know if it will be without errors. Fahmon said nothing about that.
If there were errors, it will be about 18 hours folding lost.
Jacques
Old July 22, 2009, 05:46 AM
zlojack's Avatar
Are you folding on your CPU as well? Check the priorities.
That would happen to me if the CPU client was set to the same or higher priority as the GPU client.
[SIZE=3]
Old July 22, 2009, 06:31 AM
Gellidius's Avatar
i think my priorities are set ok, as you can see for yourself if you check my PPD for the GPU (folding@home), and for the CPU (Rosetta and Poem).
Core priority is set at "slightly higher".
this problem has happened only on this particular WU, as far as i know.
Jacques
GTX 280 vs GTX 280 SLI...Benches rjbarker Video Cards 39 November 16, 2008 03:36 PM
XFX GTX 280 or e-VGA GTX 280 CrimsoN Video Cards 13 October 17, 2008 11:40 PM
GTX 280 vs. GTX 260 vs. 8800 GTX review -n7- Member Reviews 11 September 27, 2008 10:00 AM
GTX 280 Now Folding for HCF SKYMTL HardwareCanucks F@H Team 26 June 17, 2008 01:23 PM
